Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
C2424 locking up
Have a c2424 that locks up on multiple copies from adf and when adding paper.when copying using adf machine locks up around the 6th page .everything just stops and buttons dont respond,machine has to be turned off and on .when pulling out paper tray to change paper machine locks ups with paper tray 2 missing.
  • 11 more comments
  • rolodjla Jan 08, 2009
    I should find what in the function submenu? what am i looking for when a get into service mode?
    once i get into service mode like the solution says what do i look for or try next.
    do not know what you mean by photoconductor, this machine does not have one
    this machine has version 17.226,the latest is 17.227 but it says only for machines with serial numbers between vvk000001-vvk004517 . this macine is vvk019856 which is out of range.
    the machine is only used as copier not connected to a printer
    tried nvrm reset already
    machine is only being used as a copier and is not hooked up to any computer.
    all the problems similiar to this one ask for nvrm reset.i have already tried nvrm reset
    this machine is not connected to network,it is only used as copier
    adf is the document feeder and machine is a year old with only 300 prints
    I am not at the machine right now and will try it tomorrow.i will try diagnostics check and let you know.thamks
  • rolodjla Jan 12, 2009
    today i went back to the machine and got into service mode by turn on maxhine and holding down back and info problem.did not know what to check from there so i just exited diagnostics and did an nvrm clear again.i checked the fault history to see if any faults occurred and the last one was in june which i took care of.it was a 7,010.43 error. today after i did all of this the machine has had no problem.last week i could not make more than 6 copiess using doc feeder without it locking up. i will have to keep an eye on it and see if problem reoccurs.
  • rolodjla Oct 21, 2009
    I am still having the problem.machine still locks when pulling out tray and when copying from doc feeder.bestdarngood said to download updates.What do you mean by updates and where can i find updates and instructions on how to do it.
  • Xerox Master
  • 19,396 Answers
That is not a firmware problem, you can run the service menu and reset vram, and you will probably see the problem coming back.
That is a defective key pad and must be replaced.
Posted on Jan 09, 2009
    Sergeant:
    Champion:
  • 247 Answers
What is "adf"? how old is the copier? maybe it is just time to buy a new machine.
Posted on Jan 08, 2009
  • Thomas Jan 08, 2009
    you can also try this:
    1. Turn the system power ON.
    2. Wait for the Xerox logo to begin moving across the display.
    3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
    4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
    5. then run a diagnostic and then let me know what happens from that.
    thanks
    tom
    did you try my suggestion?
  • 59 Answers
If printer is connected to the network go to this site:
http://www.phasersmart.com/
Enter the ip address of printer and let it figure out whats wrong.
    Master:
  • 416 Answers
Http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=95,E=0000000001160555623,K=5685,Sxi=11,UseTemplate=Browse.tem,Remove=All,Problem=obj(407),VARSET_RestrictFolderSearch=Other_Problems_C2424,Query=""
These are references for support page for this machine
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_c2424_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_C2424):str(C2424),question=ref(ProdFamily):str(Prod_C2424),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:C2424,varset=prodName:WorkCentre%20C2424
and for driver downloads
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=C2424&Xlang=en_US&Xcntry=USA&source=XOG
Good Luck
    Sergeant:
    Novelist:
  • 326 Answers
Its the problem that your pc requires certain amount of space in the operating system.as that sapace is not available.and your printer is heavy duty printer that requires certain amount of space and that your systyem is not having in it.just delete some unwanted files from the operating system.also delete it from the recycle bin.as you said it gets stopped on the sixth page.just try to print a single line document from the printer.and give more then 6 pages.it will print normally.as printing that documents the printer will not get that load.its just the problem that your operating system is full now and needs to be made empty to make the printer work properly.
    Sergeant:
  • 378 Answers
The printer inbuilt memory has a problem in it.also try  reloading the printer drivers again and check .many a times this solves the problem. thanks.
  • 3,037 Answers
Hi rolodjla
You need to download any updates and software available on the xerox website via usb cable that you don't have and the problem should go away. Let me know if you need help finding the right software.
bestdarngood
    Genius:
  • 1,550 Answers
The photoconductor is not working properly . Try removing it and place it once again to check whether it is working properly . Else you need to replace photoconductor .
    President:
  • 2,110 Answers
Try below.
  • Sibananda Jena
    Sibananda Jena Jan 08, 2009
    1. From the System Setup menu, go to Information --> Troubleshooting -->
    Service Tools menu.
    2. With the cursor at the top of the Service Tools menu, press both the Up Arrow
    and Down Arrow buttons to display the Hidden Service menu.
    3. Reset NVRAM is in there
How can I fix a paper jam in my Panasonic 4530 ?
look inside the printer, some where in or around where the paper feeds from the area there is a piece of paper that is stuck or has ripped off inside the machine, you going have to look with flashlight follow the feed rollers and you will find paper, paper clip, a staple, dirt, something blocking the rollers or feeder from working right.
www.ask.com/panasonic_4530_paper_jam/
www.ask.com/panasonic_4530_error_code_j50/
www.ask.com/panasonic_4530_where_is_paper_jam_located/
Apr 22, 2015 | Panasonic WORKiO Office Equipment &...
Xerox documate 752
Your document must be in place/position to be scanned, faxed, etc.
Place document, then scan. ADF is your automatic document feeder. Used when copying/scanning multiple pages. Reload and try again.
Aug 29, 2013 | Sewing Machines
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Unable to use ADF. Red light under start button.
Examine the full paper path of the ADF. Look underneath as well. Could be something as simple as a staple caught deep inside.
Mar 16, 2010 | HP LaserJet 4730mfp All-In-One Printer
Canon MF6530, intermittent blank copies using ADF
Its an laser shuter problems, you can say its factory error, if its under varanty call service to fix it
Feb 11, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Apr 09, 2007 | Ricoh Aficio 1018D Copier
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
