Friend just got PC & after prompts by system to up-date Windows XP Home she proceeded through instructions. She was asked if she wished to replace current version and clicked yes. The wizard then requested Authenticity code. As she is not familiar at all with computers she was not aware it was on computer & abandoned installation turning power off Now when she turns computer on there is a beeping sound and monitor is saying No Signal She now has code and disc but cannot proceed to re-load the repair/reinstallation CD. What should she do
Follow the tips below to fix the problem:
Switch ON the PC, boot the PC
in 'Safe Mode' by continuously tapping F8 button after you switch On until you
get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
