Sony Bravia KDL26S3000 TV
I own it for less than a year - stopped going on this afternoon. - when it is switched on either by remote or directly, the green light comes on and is followed by the red standby indicator light which blinks for 8 blinks at a time and nothing else happens. What can I do??
  • alke4life May 05, 2009
    the power/standby button starts green then quickly flashes red. The picture never turns on.
  • 2,335 Answers
According to the service manual if the red light is blinking then the TV may need to be service. Since your TV is less then a year old, still under manufacturers warranty.
I would suggest to contact Sony to ask them for the nearest authorized service center to have the tv repair.
Good Luck.
Posted on Jan 07, 2009
  • Jaime Hernandez Jan 07, 2009
    Call Sony to ask them for an authorized service center near you to have it fix under warranty since is less then a year old.
    Good Luck,
    Try and see if this works before taking the TV for servicing. The TV needs to be in standby mode.
    RESETTING TO FACTORY DEFAULTS
    Use the following instructions to restore the User Controls and Channel Memory settings to the preset factory conditions.
    1. While holding down the arrow up on the Remote Commander, press the POWER button on the Front Panel of the set. The set restarts and displays the initial setup screen.
    This may take several minutes.
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
Rc65x not working with sony bravia
Direct TV rc65x code for Sony Bravia is 10000
Setup Instructions
  1. Set the "Mode Switch" to Device 1 (in the case of the rc65x set on TV).
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code above.
  4. Try your new code and tell us how it worked!
    (It worked perfectly for our Sony Bravia using our rc65x remote)
    & Goodluck!
    http://www.ezremote.com/setupcodehelp/DTV2/dtv.html?product=DIRECTTVRC65SW2009#search
Jul 25, 2012 | Directv RC65X Universal Remote Control
Retune channel every day
when you tuned after that try to exit menu by using remote press ok from remote.
by pressing ok it will save in memory .
Nov 14, 2011 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Sony TV flashes 13 times and stops
I, too have a KDL52 also less than 2 years since purchase and have the same problem this morning 2009 Oct 2
Aug 08, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a new Sony Bravia 46inch LCD tv with direct TV remote RC64R, what code can I use to get my remote to work? I've tried all the codes in the book.
i have a 46 inch sony bravia that i bought in 2007. recently i have noticed that the screen is showing horizontal lines (purple?) about that come and go. any advice would be greatly appreciated
Jul 11, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Sony Bravia 32 inch HD LCD tv has vertical lines going down 2/3 of screen. No idea what problem is. Tv is less than a year old, but I have lost the receipt. Anyone had this problem or know what may be...
We had a similar issue although our Sony Bravia was 21 months old. We were told by an engineer that the panel has failed and that the cost of replacing it would be about 900. We were also told that this is a very common fault and that the "normal" failure time was within 18mths to 3 years. If you registered your TV purchase with Sony, it might be worth contacting them with the serial number to see if you could get it repaired under guarantee. We have now bought a TV with a 5 year guarantee!!! (not a Sony!!!!)
May 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
It is a Bravia Sony Plasma TV - (No volume)
Thats right, let me know model number of Bravia TV to see its schematics.
also let me know when you press volume button on remote does TV shows volume bar on screen?
Nov 22, 2008 | Televison & Video
Televison & Video Logo
397 people viewed this question
Top Televison & Video Experts
