Question about Xerox Phaser 8400 Laser Printer
Still having paper feeding issue
Tried cleaning all the rollers but the paper still cannot feed through.
Do you know if the Maintenance Kit roller is supposed to make contact with the large aluminum roller? I opened the side cover and observed the Maintenance Kit lift and make contact which is transferring silicon onto the large roller.
  • Anonymous Mar 18, 2014
    A child stood inside my i need foot massager and now the large roller inside has been detatched from its holder. I can hear it rolling around inside. I've tried opening the back up but can't get it open.
    President:
  • 2,072 Answers
Yeah it should make contact with the drum, but it moved up and down to make and break contact with a clutch.
What I strongly suspect is that you have a bad registration clutch. That drives the rollers just out of the paper tray and is very prone to failure.
If you want to try and replace that let me know, I can get you the part number to order and tell you how to replace it. It really is not hard to do at all.
Just removal of the left side cover and a couple of clips.
Posted on Jan 13, 2009
Cannon MP 250 crayon stuck between rollers
Description
Cleaning the Paper Feed Roller - MP250 / MP270
Solution
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
Oct 28, 2017 | Office Equipment & Supplies
The sprinter gives a message cleaning the paper path
Check* was paper physical length is matching to selected length? *check Maintenance kit interval. * check which tray you are getting this message? tray/tray 2 check pick up rollers are warn out? * clean paper path sensors.
Sep 30, 2011 | HP LaserJet 4250n Printer
Hello. During printing I often can see error message 13.01.00 - paper jam, but really nothing jammed. I have printer HP LaserJet p3005. Thanks
Your printer has a misfeeding problem.
It never fed any paper so the sensor never sensed paper and thinks that there was a jam.
Try using the manual feed tray. If that works, pull out tray 2 and clean the feed roller . Is this printer
up to date on its maintenance? The feed roller might have to be replaced.
Mar 16, 2011 | HP LaserJet P3005 Printer
Where is the maintenance kit on hplaserjet 4345mfp
The maintenance kit usually consists of a fuser which is on the left side just below where the paper comes out, a roller, which is on the right side inside of the manual feed tray, and about 6 new paper feed rollers, which are in the paper tray at the bottom.
the HP model is Q5998A, and they'll run you around $275 for an HP branded one. It has complete instructions on how to replace the parts with the maintenance kit.
May 14, 2010 | HP LaserJet 4345mfp Printer
Phaser 8400 w/ Maintenance Kit problem
Sorry for the delay in responding. I am sure you have a bad registration clutch. Let me know and I will forward you part numbers , phone numbers and directions. Easy to replace.
Jan 07, 2009 | Xerox Phaser 8400 Laser Printer
Paper jam related to Maintenance Kit
I wonder if you got some of the silicon lubricant from the maintenance kit on the rollers.
Try taking some alcohol or a cleaner such as fantastic, 409 etc and throughly clean all the rollers in the paper tray and along that transport behind the door.
If it isn't getting out of the tray you may coincidently have a smoothe feed roller, if it is feedinf a couple of inches out of the tray and stopping in the lower rollers I suspect a slipping registration clutch. Removing the maintenance kit seems like an odd thing to start a jamming problem. As I said clean the rollers, I guess see if you happened to have gotten a chunk of ink in the paper path from the catch tray.
Is there any damage to the paper? And tears or dents in the page?
Let me know we can resolve the problem.
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
Paper not feeding
The Dell 3000cn & 3010CN both display this fault.
The root cause of the problem is the Rubber pads of the feed roller in the paper tray become warn and fail to grip the paper the paper feeds a few millimetres and then is let go by the worn roller, the paper path sensors pick this up and then a paper jam is notified.
The only remedy for this problem is to obtain a new feed roller for the paper tray mechanism. Unfortunately dell in the UK do not sell maintenance kits to the public, and therefor ehte only place I found them wa on Ebay in the USA.
The kit in quetsion is the vertical paper feed maintenance kit. it costs around $50 plus shipping.
The only other option is to have a Dell approved service agent replace the rollers for you.
If you hear a grinding or cruching noise when paper is fed, then one of the mini plastic guide rollers had detached itself from its position and wound up in the tape path mechanism (very expensive repair)
Jul 12, 2008 | Dell 3000cn Color Laser Printer
XEROX DOCUMATE 510
The rollers and retard pad need replaced.
The rollers are self explanitory, the retard pad is so named to retard the feed of multiple sheets of paper.
That is your problem.
Nov 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox Phaser 8400 Laser Printer Logo
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
