Question about LG WM-2032H Front Load Washer
Washer will not spin
Error code CE comes up as motor overload...is this something we can fix ourselves(maintenance dept at school)
    Genius:
  • 2,920 Answers
You will want to call someone in to take care of it ...its likely the motor is fried
Posted on Jan 07, 2009
Kenmore He4t front load washer f 06 error code
This answer is actually from Sears Parts Direct: The F06 error code
indicates a drive motor tachometer error. This error is virtually impossible to accurately diagnose. The most suspect components that would cause this failure code are the drive motor, the motor control unit (control board) or the wire harness. In some instances, this could be caused by severely overloading the washer so that it cannot spin properly. Make sure that the washer is not overloaded. Another problem that could cause the error code to be displayed intermittently would be a loose wire harness connection that is affected by vibration when the washer is spinning at high speed. Good lucks, hope it helps
Dec 07, 2014 | Washing Machines
Cabrio washing machine wont finish spin cycle and comes up with a code blinking F 51. how do i fix this problem I cant finish one load of laundry, without this cod F 51 poping up. thank you wendy
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the Kenmore Oasis Washer Model No. 110.27082603 and keep getting an error code "F51". What is it telling me? What needs fixed?
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Sep 12, 2010 | Kenmore Washing Machines
Is there a way to fix an error f51 code myself...like a reset button
Sep 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing ce
Most all error codes on a Calypso end up being a pump problem. If all the water can't be pumped out, the tub gets too heavy for the motor to handle and it will cause a CE error code. Something like lint or wire or screw may be caught in pump impellar. If your not familiar with repair you need to call for service.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Caliypso washer problems
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Mar 28, 2009 | Kenmore Washing Machines
C1 error code
CL code stands for overloaded motor. Motor is drawing to many amps and cuts out. I suspect a failing motor or something binding that causes the motor to draw to many amps. Don't know how to fix it.
Aug 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
LG WM-2032H Front Load Washer Logo
235 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
