Question about LG WM1814CW Front Load Washer
MSRP Nobody will tell me what the manufacturers suggested retail price was for LG Front Load Washer WM1814CW.
    Genius:
  • 2,920 Answers
Its about 800.00 to 1000.00 with the base, depending on where you choose to go to buy it.
Posted on Jan 07, 2009
Problem with LG WM1814CW Front Load Washer. It has stopped with water inside and it says OE. I have checked the back pipe, but with water inside, can i open filter
The OE error is telling you the water hasn't drained out in ten minutes. To fix I would first start with cleaning the filter on the pump. If that doesn't fix i would recommend replacing the pump. I would also have towels and a mop in hand because when you unscrew the filter top the water that is inside the tub will come out. You should try leaning washer back before removing filter to prevent the mess.If you have to replace the pump they run about 50 or 60 bucks. I hope this helps.
Oct 27, 2012 | LG WM1814CW Front Load Washer
What would be the cost to replace the water pump in 2001 Mazda MPV at a local shop?
That all depends on the local shop. Labor rates vary from area to area and from shop to shop within the same area.
What I can tell you is this:
The Manufacturer Suggested Retail Price (MSRP) for the water pump is $167.13 (USD)
The standard labor time required to replace the pump is 2.0 hours.
The cost of antifreeze will also vary depending on the local shop and what brand of antifreeze they use.
I would suggest that you call the local shops for estimates. If they charge more than MSRP for the pump or if they charge more than 2.0 hours labor time to replace it, then you should get another estimate from someplace else.
Sep 17, 2011 | 2001 Mazda MPV
LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
May 20, 2010 | LG Washing Machines
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
My white clothes are coming out dingy and gey from my LG front load washer
I have an LG front load washer too and sometimes my whites don't come out as nicely as they should. Usually draining the machine and running several cleaning cycles solves the problem. I hope it works for you!
Jan 08, 2010 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
The OE Message on my LG Tromm WM1814CW
Open the little trap door on bottom front of unit. Unscrew lint filter trap. Drain water first with small tube.
Sep 08, 2017 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
63 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
