Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch Washer dryer is stuck on lock at wash time left 0.01.
I have tried holding down every button for 5 seconds!!
barkencoa
  • 3463 Answers
SOURCE: bosch 1200 classixx not working properly. On 12
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Posted on Dec 13, 2009
SOURCE: Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Posted on Mar 29, 2011
taran_2005
  • 10515 Answers
SOURCE: I tried to wash an
Is it flashing only E or there is a number besides it such as E 03 or E1?
Thanks and Regards
taran_2005
Posted on Jun 13, 2011
  • 6277 Answers
SOURCE: Have a bosch WAE18060AU front
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
richroth
  • 9472 Answers
SOURCE: how to unlock childlock on washing maschine model Bosch WAS32794ME. Error : F:00.Thanks.
You need to press and hold the OPTION button (<) for 5 seconds.
Posted on Oct 31, 2012
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
Tip
How to Unlock Any Appliance or Turn Off Child Lock
<span style="font-weight: bold;">Bosch Dishwasher:</span><br /> <ol> <li>To deactivate, press and hold the "&lt;" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br /> <ol> <li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br /> <ol> <li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br /> <ol> <li>Press the Menu button until CHILD LOCK :ON appears in the display.</li> <li>Press the Select button until CHILD LOCK :OFF appears in the display.</li> <li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br /> <ol> <li>Press the control knob or button and hold it in place.</li> <li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li> <li>Turn the knob clockwise and select the code "0033."</li> <li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br /> <ol> <li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br /> <ol> <li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br /> <ol> <li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br /> <ol> <li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br /> <ol> <li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br /> <ol> <li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br /> <ol> <li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br /> <ol> <li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br /> <ol> <li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br /> <ol> <li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br /> <ol> <li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br /> <ol> <li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br /> <ol> <li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br /> <ol> <li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br /> <ol> <li>Press and hold Cancel for 10 seconds.</li></ol>or<br /> <ol> <li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br /> <ol> <li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br /> <ol> <li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br /> <ol> <li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br /> <ol> <li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br /> <ol> <li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br /> <ol> <li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br /> <ol> <li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br /> <ol> <li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li> <li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br /> <ol> <li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br /> <ol> <li>Press and hold "options & select" until the light goes off.</li></ol>or<br /> <ol> <li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br /> <ol> <li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br /> <ol> <li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br /> <ol> <li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br /> <ol> <li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li> <li>Press cursor up/down to select CHILD LOCK and press cursor right.</li> <li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li> <li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br /> <ol> <li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br /> <ol> <li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br /> <ol> <li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol>
on Jun 17, 2011 | Washing Machines
NrO fault code on bosch logixx 8
nrO is child lock. Hold start button for 5 seconds to remove.
Dec 07, 2012 | Bosch Logixx WFT 2806 Front Load...
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
Un lock child lock 10d52 seimins washer dryer
to deactivate the child lock, set program to Easy-Care and hold option down arrow for 5 seconds. If still it does not get unlocked then Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds.
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD
Jun 26, 2011 | Washing Machines
How do i deactivate the child lock on the bosch axxis washer
Hi
To unlock the washer press and hold 'dry' & 'spin' button. It should unlock now. If this doesn't work then press and hold "end of cycle" button for 5-10 seconds. However, if it is still locked then unplug the washer for 5 minutes and then plug it back. After plugging it back press and hold Start button for 10 seconds to unlock it. Hope this helps...
Daniel
Aug 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool dryer is locked control locked.
the controls on our unit can be locked by holding a button for 3-5 seconds.
look on the control panel for a "paddle lock" symbol next to one of the buttons. cant tell you which one as they do change from year to year.
just find the right button and hold it in for a few seconds. then it will beep and should unlock after that.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Jan 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
64 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
