Question about GE GSH25JFR Side by Side Refrigerator
Variable fan, moaning
Does anyone know whether this fridge is supposed to have a variable-speed fan? Mine is varying. I don't know whether it is a feature or a problem. It sounds as if something may be loading up, electrically speaking, intermittently, and dragging down the fan voltage. As the fan spins down to the lower "speed," or back up again, it passes through some kind of resonance, producing a tone or moaning sound. It sounds as if it is haunted by a ghost. Yes, it cools OK, but I think it's running too much lately.
  • 7 more comments
  • Ben Cook May 30, 2007
    Thanks. I found the User's Manual athttp://www.geappliances.com/service_and_... Inside, it says, "The fans change speeds in order to provide optimal cooling and energy savings."
    It's not the fan itself that is moaning, but rather it's the air moving through a space at just the right speed to resonate as the wind speed varies up and down way too frequently (seconds). The problem is that the fan speeds up and slows down way too frequently.
    Elsewhere, I found several reports of the same problem, which indicated that it's a bad Main Controller Board failing to control the fan speed in a sensible way. GE's part number is WR55X10552. I'll give that a try....
  • Ben Cook Sep 09, 2007
    Just to report back: I did order a new Main Controller Board from GE. I asked if there was any way to get it for free, since I suspected my old one was defective, and the answer was ABSOLUTELY NOT. You pay! OK. I pay.
    Later, I received a call explaining that I will NOT be charged. It's free! After that, I received another call verifying my scheduled service call time. I never scheduled a service call, and this subject matter never even came up, not even in the faintest expression, so I canceled that. Weeks later, I called back about my free Main Controller Board, and they said it was canceled. Thank you for that. So I ordered it again.
    When it did finally come (still free!) there were 3 parts broken and a fractured trace on the board. Not wanting to risk going through all that hubbub again (and maybe having to pay), I replaced the broken parts with parts from my old board, and wired around the broken trace.
    THIS HAS SOLVED MY PROBLEM. In the three months since the board replacement, I have NOT heard one moan or ghostly sound from the unit. Prior to that, it was a daily occurrence.
    Correction: I guess it hasn't been 3 months. Maybe 2 months. Anyway, the problem is solved by GE part number WR55X10552.
  • russell05 Dec 01, 2007
    I have the same problem. Seems like the fan is on a rheostat and someone turns the voltage up and then down. Some times it sounds like wind moaning around a corner or in a window. Does this seem like the same problem you have. Oh by the way it is cooling and freezing fine just making a weird noise.
    Russell
  • Ben Cook Jan 23, 2008
    Russel, I'm glad that it's fixed!! I hope they gave you the board at a low cost. I'm convinced it is a manufacturing defect.
    Mine's been fine for a while now. Not a hint of ghosts for many months now. To answer your question late, yes, that was my symptom as well. (I apparently only get email notifications from this forum for posted solutions, and not comments). Anyway, I do think it *IS* a variable-speed fan controller by design; and it's just that it needs to be controlled in a sane manner.
  • 60srocker Feb 12, 2008
    Add me to the list of folks with the same problem, just not on the exact same model. Mine is a GSS25JFPC-WW. It probably uses the same board. I have sent a nastygram to GE (God's Enemy) requesting a new board for free!!!!
  • Anonymous Aug 03, 2008
    I have the same problem that's described in your posts. Thanks for identifying the issue. I'll have to call G.E. and get a new (as in free) board. It certainly fits into manufacturers defect category.
    Is it difficult to replace this yourself?
    Thanks,
  • mskorea98 Aug 27, 2008
    So, we have the same problem. Been hereing the ghostly, whining noise out of our freezer for the last few weeks. It comes and goes but seems the most obnoxious in the middle of the night. I did some research online and it all seems to point to the faulty motherboard/controller board. I called GE who at first told me that it had nothing to do with the motherboard and that they would set up a service call (that we'd have to pay for). I asked to speak to a supervisor and she said that she would need the serial number to determine whether ours was one of the ones that qualified for a free motherboard. I didn't have that with me so I have to call back with it. If it is one of the ones, then they said they'd send out a technician and he would have to determine whether it was indeed the motherboad that was the cause of the noise. If he didn't, then we'd have to pay for his visit and whatever part he determines we need. The only reason we even have GE appliances is because it came in the house that we bought. We live in a condo complex and most of the other units have all had some kind of problems with their GE kitchen appliances in the 2 years that we've lived there. We will definitely not buy GE again.
  • Buck44 Nov 28, 2008
    Have the same problem of moaning. Had Evaporator fan replaced, and that seemed to work for almost a year, but it's back!
    Arrgghh!
    The vegetable bin (bottom bin) has a circle of frost about the size of a soup can.
    We have it set to "2" coolness. Model GSS25JEPD side by side
    BB
    New Friend:
  • 3 Answers
Genuine appliance part sales (google it) sold me a motherbaord fror 98 bucks, took less than 5 minutes to install and thought the fridget did not work because it was running so quitely, tried to resolve issue thru GE and got the run around,i would have had to pay for a service call for the estimate and they would not bring a motherbaord with them, the only tool you need is a 1/4 socket or nut driver....done too easy...
Posted on Aug 02, 2013
Changed out the main controller board and mine and it is fixed. No more sounds of the fan speeding up and slowing down and no more moaning sound. Hope this helps someone else
Posted on Jan 22, 2008
  • 883 Answers
A variable-speed fan is highly unlikely for this unit. your fan needs to be replaced or serviced with 30W oil on shaft bushings
Posted on May 30, 2007
SOURCE:
Fix a dw788 dewalt scrollsaw thtslost its speed cotroll
Do you mean lost as in 'completely missing' or as in 'stopped working'?
The only moving parts are the on/off switch and the speed control knob and variable resistor. On mine, I had to replace the variable resistor pot. You have to get one with the same resistance rating. If you know what it is, you can get them off ebay. Doesn't have to be designed for a scrollsaw. They're all the same whether they're for a saw or for a radio volume control. Only the resistance needs to be matched. (Well, the way the knob fits on the post has to match too.)
Dec 08, 2014 | Dewalt Saws
What is the difference between independent and dependent variable
Independent means that it does not depend on, does not rely on, is not affected by anything. A dependent variable is a variable is affected by some other variable. If. the independent variable happens to change its value, the dependent variable must comply and change also according to the rule that connects the two variables.
An example of independent variable is time. It runs its course, not affected by anything else.
Maybe a money example will be more transparent.
Suppose you have a part-time job to support you in your studies. In a part-time job, the number of weekly work hours is not fixed in advance. Some weeks you are relatively free and can work more hours. Other weeks you have exams and can't do as much.
Let us consider the situation: your weekly salary. You understand that your weekly salary will vary in relation to the total number of hours you work during a given week. The more you work, the more you earn. The less you work, the less you earn.
Clearly there is a link between the number of work hours, and the weekly salary. You have two quantities that vary from week to week. They vary: so they are called variables (variable= capable of varying/changing its value).
The two variables are x= number of hours worked in a given week, and y= weekly salary earned in the same given week.
You and only you can decide of your own free will on the number of hours you will work that week. However, once you choose/decide how many hours you will work, your salary is calculated according to a set rule your boss and yourself had agreed to.
Of the two variables in the situation describing you weekly salary, the number x of hours worked is the independent variable. The weekly salary y is the dependent variable: the amount of money you get depends on/ is decided by the number of hours you worked.
Please use a dictionary to see the meaning of the verb to depend on, and the adjectives dependent, independent.
Sep 28, 2014 | Office Equipment & Supplies
I have a project and i don't know what independent or dependent means
When conducting an experiment, a researcher usually has a dependent and independent variable. The independent variable is the variable that can be changed or manipulated (think of it as a cause). The dependent variable is the variable that depends on the independent variable (think effect).
For example, if you wanted to test whether practice improves an athlete's performance (lets say number of touchdowns):
  • Practicing (or not) is what you can manipulate. It is the independent variable.
  • Number of touchdowns is the dependent variable. The results depend on whether or not the athlete practiced.
Sep 07, 2013 | Finance
Ryobi 18v variable speed impact driver. I need to know something about speeds and settings. Bob
Just keep it on high, vari-speed on an impact driver is not very useful unless working with delicate materials.
Mar 23, 2010 | Ryobi 18v Variable Speed Impact Driver...
I have a dell optiplex gx280 which seems to have a racing fan problem. sounds pretty loud, and varies. any ideas?
The fan bearings may be going bad. Variable speeds are normal as the fan adjusts to the cooling requirements.
Oct 24, 2009 | Dell Optiplex GX280 (99301) Motherboard
Variable speed fans suddenly slow single speed only.
check with the temperature of the CPU core!
because of over heating the CPU is shutting down or not.
Sep 24, 2009 | IBM Computers & Internet
Need a replacement fan speed potentiometer.
Okay -- first off, I don't know where she got that number from, but that's idiotic.
The variable-speed switch will provide different readings depending on where it's turned to. If the switch is busted ("open), it will typically display a reading of 'infinity' on your ohmmeter.
And yes -- the best place to find a replacement is Radio Shack, since Casablanca discontinued them.
HOWEVER---
Casablanca's variable-speed ceiling fans -- specifically the "SlumberQuiet" ones, which were made from circa 1980 or 1981 to the early/mid 1990s when variable-speed was discontinued -- are well-known for breaking down. The problem is almost never the potentiometer (variable-speed dial). Rather, the problem is almost always the resistor which is mounted in the heat-sink inside the fan's motor housing. There are NO replacements left for these -- so Casablanca makes a "variable-speed to 3-speed conversion kit", which will convert your fan to a more normal 3-speed pull-chain (hi-med-low) setup.
I hope that helps! If you have any other questions, please feel free to ask!
Jun 16, 2008 | Casablanca Fan Dryers
GE GSH25JFR Side by Side Refrigerator Logo
1,162 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Jeff sanchez
Level 1 Expert
