Question about Zanussi FJ1254W Front Load Washer
Grey sludge on my washing
My Zanussi 1254W seems to be throwing grey slimy sludge back over my washing. I've tried using a washing machine cleaner at high temp. and fitting an inline anti-syphon device to no avail.
Any ideas?
    Problem Solver:
  • 6 Answers
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Posted on Mar 30, 2009
Gunge in door seal samsung Q1233 washing machine
It's caused by using too much soap powder or fabric conditioner,it doesn't get rinsed away properly and goes greasy & slimy,,,,,if its starting too smell change door seal,,,,,use bicarbonate of soda 1 or 2 times a month, no clothes or detergent,& on a 90 degree wash,,,that should stop it returning
Jun 19, 2013 | Washing Machines
Machine leaking, grey tube at bottom of machine has come loose from somewhere causing it to leak. what is this for ?
grey tube is actual 'pipe' that should be attached to the pump which empties the drum.
(a) Lay washing machine on side with a couple of blankets under neath to save damage to the side.
(b) Look underneath the machine and you will see where the grey tube should be affixed. suggest if you cant find the retaining clip, purchase a
1.5" (3cm) jubilee clip and tighten around the grey tube to hold it in place.
May 18, 2012 | Zanussi Washing Machines
How can I stop my washing machine from smelling and producing smal grey lumps of muck ,the seal and drum are cleaned regulaly also have tried washing machine cleaner
As with Mieles I would recommend that you run a few more hot wash cycles, the build up of gunk over the years would have accummulated - there are Gurus out there with remedies to make it smell nice, I have not tried the natural remedies yet.
Jun 20, 2011 | Zanussi ZWF1440 Front Load Washer
Smells grey sludge on clothes
its from all the old detergents not getting to the drain and lay in the outer wash tub,the smell is from mold starting to form in this gooey mess,you may need to remove the inner tub to get this goo out of the outer tub,then make sure the drain pump,hoses are also clean of this goop and there are no kinks,or blockages in the drain hoses or pump
Apr 29, 2010 | Bosch Washing Machines
My Zanussi FLA1001W will wash but will not sin or
Check the impeller on the pump free to move. if ok check electrical connections. if ok either pump is faulty or it could be main pcb (or both)
Oct 17, 2009 | Zanussi FLA1001W Front Load Washer
Bad bosch
The grey sludge may be due to incorrect soap powder (use only front loader) or excessive powder use. Minimise the powder use and insure you do a very hot wash once every 4 weeks to break down powder that may be building up.
Regards Sam
Apr 15, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Scum on my clothes espically whites help
you need to do more washs on 90 but dont put bleach in its just sludge build up between the drums vey normal ffrom doing warm washs all the time i do 95 degree washs evey three months to keep machine clean.hope this helps.
Mar 26, 2008 | Zanussi FJ1454W Front Load Washer
Zanussi FJ1254W Front Load Washer Logo
842 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
