Question about Acer Aspire™ T180 PC Desktop
CD Drive not working at all
My CD drive doesn't work; it isn't even listed when I open "my computer"; I've uninstalled and reinstalled. I've tried several CDs.
I have a Gateway GT5464 model. Any suggestions would be appreciated. Thanks
In the Device Manager - it shows this:
DVD/CD-ROM drives
ATAPI DVD A DH16A1p ATA Device
and it has a caution sign (exclamation point) i have the same problem. It was a IDE drive so i switch the CD drive and put another one on. The new drive was SATA but it still showes the same problem...I DONT GET IT..PLEASE HELP>>>
  • Anonymous Feb 01, 2009
    I have the same porblem code 37
  • Thomas F. Schneider May 11, 2010
    Your question is listed under Aser aspire model T180.
    When you stated that uninstalled and reinstalled several times you are talking about the software , correct? An IDE drive would have to be set to Slave or Cable direct. Was it? The S ATA drive would have to have a driver installed .
    http://support.gateway.com/s/PC/R/100956...
    President:
  • 846 Answers
If its the only CD Drive on that IDE cable it wouldn't be set as slave, would be on Master.
Yes you can go to http://www.driverguide.com you can download updated drivers for IDE and SATA on your PC.I checked on Acer support but there website isnt't working correctly for me.
Try updating the drivers, and try both drives again one at a time.
Posted on Jan 07, 2009
Your display adapter is the component of your computer that allows your monitor to work. On the operating system side of things, this display adapter is controlled by a device driver. If you're having issues with your display adapter (like colors are displaying incorrectly or the screen is flickering), you can fix these problems by rolling back your device driver using the Windows Device Manager.
Open your Control Panel by clicking "Start" and then "Control Panel." Click "System." Click "Device Manager." Scroll down to the "Display Adapter" heading. On a single monitor setup, there will only be one device listed under "Display" adapter. Right-click it and click "Properties." Click the "Driver" tab. Click the "Roll Back Driver" button. This will uninstall your current display adapter driver and reinstall the last version that worked properly. This will fix the issues you were having with the device. Hope this helps
Jan 16, 2013 | Acer Aspire 5735 Notebook
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
Dvd drive won't open
http://www.pchelpforum.com/cd-dvd-rom/75829-dvd-drive-wont-open.html
click here and read the many solution, aplly one which will suits according to your problem
thx
Jan 07, 2012 | Dell Inspiron 1501 Laptop
My laptop (acer) doesn't play DVD movies or audio CDs what can I do to fix it?
Eject the DVD tray and clean the laser lens with a piece of cotton.
Enter to Setup Bios (Restart the PC and press " F2" key to entert BIOS setup and see if the DVD drive is show in device
restart
In windows..go to control panel
devide manager and look if They are a yelolow mark bnear the DVD drive
Click and UNINSTALL
Restart the PC.
If don´t work , may be the DVD drive is faiulre
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Computers & Internet
My LiteOn iHAP422-98 9 IDE drive will read but not burn CD/RW discs. No problem with DVDs or CD/R. One of two error messages, depending on the CD/RW disc: 1) Doesn't recognise a disk is in the...
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 14, 2011 | Lite On iHAP422 DVD+R Burner
Hey guys, I've fluffed up something on my win7 computer, PIONEER DVD RW DVR-107D ATA Device haven't got a clue what I did to make it go wrong but it no longer plays movie data that I have burned...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 22, 2011 | Pioneer DVR-107D DVD±RW Burner
I can not open my usb flash drive
Try it on a different computer; it may be your USBconnection. You could try to uninstall it or update the drivers by clickingSTART, CONTROL PANEL, SYSTEM, HARDWARE, DEVICE MANAGER, and USB controllers atthe bottom of the list. Try updating the drivers first by RIGHT CLICKING andchoosing update. If all that doesn't work try RIGHT CLICK and uninstall them.The new found hardware will reinstall them automatically, if not right away itwill the next time you boot up the computer.
Jun 03, 2011 | Computers & Internet
My cd-rom drive works just fine My cd rom drive is drive D: however when I try to use the recover disks it restarts and tries to use drive Q. It says it is starting windows 98 then it says: SCDEX...
you might have to physically unplug the leads for this cd drive then plug them back in this should activate the found new hardware wizard you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 23, 2011 | Computers & Internet
Computer does not recognize CD/DVD drive
If updating the drive firmware does not work, then replacement of the drive will be necessary.
Jan 30, 2009 | HP Pavillion ZV6000 Notebook
Acer Aspire™ T180 PC Desktop Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
