Apex Digital Apex LE3212D 32-inch 720p LCD/ DVD Combo Refurbished Logo
RICHARD MATOS Posted on Nov 17, 2012
LD200RM REMOTE CONTROL DOESNT WORK ON MY APEX LE3212D
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Oct 31, 2012
SOURCE: I have a new apex tv LE3212D i bought in March the remote stopped working I bought a rca remote RCR450 none of the codes listed for apex work i have cox cab le
RCR450 have no setup codes to Apex TV. There is no RCA remote control models have set up codes for Apex brand.
DROP REMOTE FOR LE3212D DIGITAL TV/CD,NOT WORKING NOW.ORDER APEX REMOTE FROM AMAZON DID NOT WORK.UNIVERSAL REMOTE ONLY WORK FOR UP CHANNELS,NOT TURN TV ON OR OFF.HOW CAN I GET A WORKING REMOTE AGAIN?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
If you wish to get further advice over phone; visit https://www.6ya.com/
Apex tv shuts off after 2 minutes
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
How to get out of aging mode on an Apex ld3288m lcd tv
You should enter its service mode to do this.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
5helpful
3answers
I dont have a remote for my APEX tv. I have been trying to change the input from AV to TV but as I scroll through inputs I can't get it to stay on the input I want. Help?
I know this is old but I figured I can post an answer for anyone else looking for a solution. I don't have a remote for my Apex tv and wanted to switch it from TV input to Hdmi 1 to use it as a monitor. You have to press INPUT button to get the menu up. Then press CHANNEL+ or CHANNEL- to change to the input that you want. Then press and HOLD the VOLUME+ button to enter it. That worked for my Apex TV.
TV will not turn on
Check and replace damaged component/s in its main power regulator board. It will be best to replace this board as card basis. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
2answers
Ge universal remote 24991 v2 need code for apex dt250a or rca stb7766c
There is no setup codes for Apex or RCA STBs with this GE remote control.
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
