Non english display cs 5035
COPY STAR CS 5035
I got an error 0610.
I changed the memory, got the same error 0610.
I meant to reset the memory but what happen was the display changed from English to I believe Japanese.
I still have error code 0160.
How do I return to the English display?
How do I verify the correct main pcb part number if needed?
THANK YOU
  • mail2115_inf Jan 10, 2009
    Thank you.
    I did get to the screen for 018
    but the touch screen for that display would not respond.
    So I used 020 instead. I now have my English back on my display.
    Now I have error codes 0610 and 0470. What is 470 for?
    Still lost.
    Thanks again.
    I still have c 0610 code.
    It appears I need a new main board.
    Where do I locate the serial number for my copy star machine?
    I want to make sure I order the correct board model?
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; Try to return to english first, the procedure as follow;
1, press the keys in order "10871087".
2, enter 018 press "start".
3, you can checksum for the ROM,reset main board, change language.
4, enter "001" press print.
Hopefully can resolve your problem, good luck!
Posted on Jan 07, 2009
  • Everett Lin Jan 10, 2009
    Hi sir; try go to another reset the first step same as before then enter 906 then press start then press execute then press start again.
    the item# for main board is 2FG28070.
    the error code means backswitch unit problem the item# is 3CN01010
Our Copystar CS-5035 Copier is not sending the copies to the finisher, instead they are coming out in the middle of the copier.
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Jan 09, 2013 | Kyocera Copystar CS-5035 Copier
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
I would like to change the name on my scan to PC function on my CS-5035...right now it is set as Angela and I need to change that name to Shannon
go to internet explorer, type the IP address of the scanner, go to destination list on scan to pc. click your number where your name is appearing. change name and the click registration.
Sep 30, 2010 | Kyocera Copystar CS-5035 Copier
Ii need to change the number of rings before the fax machine answers on my Copystar CS 5035. How do I do this.
touch the menu button, go to fax default, key in code 6482 and then scroll settings and change the the number of rings
Aug 06, 2010 | Kyocera Copystar CS-5035 Copier
I am just trying to find the driver for a Copystart CS-5035. I cannot find anything on the Kyocera web site.
www.copystar.com go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Aug 03, 2010 | Kyocera Copystar CS-5035 Copier
139 people viewed this question
jasbo
jasbo
