Question about Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 problem
You wrote you can find firmware for Samsung YP-T9. My player are not recognised by the computer. I conect the USB cable and it shows " USB connected" and in 1,2 seconds it shows " UBS not conected" and turn off the conection, and so again and again. The computer don't show anything.  please, friend send me this firmware and you said you have a tool to add this update to player (because the computer don't show it). Please reply me at: donici.artur@yahoo.de
  • Mitosis Feb 16, 2009
    I have the same issue but it's not a USB cable short because it only happens on XP machines. On Vista it will just charge but it is never identified by any machine.
  • willbailey Apr 11, 2009
    when i connect to a computer it works fine but try and connect to another media source a sterio or my usb in the car it says usb not connected im in 2 minds if the cable is faulty any suggestions would be grateful
    regards will
  • 1,800 Answers
Look buddy first u shud get rid of the shorting out on the usb connection.
then get to samsung.com and check the support page of ur product and start downloading!!
Posted on Feb 10, 2009
My Samsung YP-T9 had frozen
hold a-b button and menu buttom simultaniously
Dec 25, 2008 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Usb conection
I have the same problem, it also will show charging after I disconnect it from PC. Anyone have any ideas?
Oct 27, 2008 | Samsung Yepp YP-T9 Digital Media Player
Can't connect to my pc
Mine had the same problem and here's how I fixed it :
First, connect your YP T9 to your PC
Once connected, on your PC go to :
-Start
-Control Panel
-System
-Hardware
-Device Manager
Then you'll se your YP T9 appear under either "portable devices" or Universal USB or USB something...And since it's not working properly, you should see a yellow exclamation point besides it.
Then click on the YP T9 with the exclamation point and right click again on it, then press "update driver"...Then follow Window's instruction to update it, it's quite easy...
That should do it! : )
Apr 05, 2008 | Samsung YPT9 Digital Media Player
Games
I have done it lots of times .You can even get new themes.All you have to do is download the latest firmware or Go to Download Center at Samsung.com
Click TV, Video & Audio.
Click Digital Audio Player.
Click Yepp.
Click your model. The name of your model is at the back of the MP3.
Click the firmware that you want.
Then you'll come to that page ...If you scroll to the bottom, you'll see
"200703221...etc"
Click on that.
You have to either have Winrar or winzip. Any "extracting" software.
Extract it to desktop or wherever you desire.
When you connect your MP3, there'll be a drive in your "My Computer" probably called YP-T9 [F;].
You drag the firmware that you have downloaded and put it in the 'System' folder.
The files should be MUON.ROM and SYSDATA.
Remove the MP3 from the computer, when you on it again, it would update automatically.
Hope that helps. =
Nov 17, 2007 | Samsung Yepp YP-T9 Digital Media Player
Problems!
You need to reformat the device and then upgrade it to the newset firmware. You should be able to find instructions on how to do this on the Samsung website.
Jul 31, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung yp t9
Firstly, "re-set" the T9 (ie hold 'MENU' & "REC', for 3 secs to re-initialise the built-in firmware - refer to your manual, or download manual off Samsung website). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T8 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. Failing this, then a replacement battery is the next step. If still under warranty (ie less than 12mnths old), then have an approved Samsung service agent look at it Free of charge. Good luck.
May 13, 2007 | Samsung YP-T8 Digital Media Player
Usb connection issues
its not your computer its the firmware you can go to samsung .com and get a older version of the firmware and put it in yourself you might haft to put it in the wma only mode to do this
Apr 25, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung Yepp YP-T9 Digital Media Player Logo
208 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
