Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
I have had my Hoover (model F7425-900) for 3 years. Of the 5 times that I have used it, I have ended up with a crack in the clean water tank 3 times. Is this a common problem with this model? If I choose not to keep it, is is possible to send it back to Hoover? Replacement on this part is $30+, I am frustrated and my wallet is exhausted!
It sounds like something is putting a lot of torque (twisting pressure) on the clean water tank that may be causing it to crack under usage. When you place the tank into the "upper" opening, then push it in until it "clicks", are you "forcing" it? If it doesn't seat easily you may be creating the torque and under usage it may break or crack. My clean water tank only cracked once. It went down a 15-step stairwell all by itself. I think they (Hoover) should make clean water tanks that can at least go down 20-steps. But ... that's just me.
Posted on Sep 17, 2007
I use shoe goo or similar product to glue the cracks together. I have fixed large holes this way and it works fine. It is best done when cracks first appear. If cracks are minor then super glue might also work but if it is major or there are holes then shoo goo does the trick and it is a permanent fix.
Posted on Sep 16, 2007
Jan 29, 2016 | Hoover Vacuums
Oct 16, 2013 | Hoover SteamVac F5914-900 SpinScrub...
Jun 10, 2013 | Vacuums
Jan 08, 2010 | Hoover C3820 SteamVac Upright Wet/Dry...
Nov 15, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
100 people viewed this question
I also have had problems with this. My first one cracked after the first few uses and so I purchased another one- and the same thing happened. Now I need to do 2 steps....go over once with soapy water and then again with clean water to rinse. Very frustrating. Other than that, does a great job cleaning carpet! If Hoover could solve this issue I would highly recommend this model.
My hoover tank cracked also, this is the fourth time, I do not force the tank in place. I can't afford to keep buying replacement tanks. please help!
