Question about Belkin (F5D5231-4) Router
XBOX Live & Netgear Router Help!!!!!!!!!!!
I have a Netgear WGR614 router. I have my NAT set to open, 3 ports forwarded and set correctly for my XBOX 360, and I still don't have a solid connection when playing online. I get kicked out of rooms alot and even off of XBOX Live sometimes. Something tells me that it has something to do with my NAT still because I can't always connect with other people. HELP!!!!!!!!!!!!!!!
  • chevy309 Mar 01, 2009
    i have the same problem. it kicks me out of rooms and games.. how can i fix this???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
You need a excellent signal to your Xbox. Xbox requires a constant connection. My son as an Xbox and we had to run a wire connection to the Xbox no problems after that. Or you need to move your wireless router to the same room as your xbox to get a stronger connection.
Please rate my response.
Posted on Feb 17, 2009
My NAT type is strict and i wanna make it open how for xbox live
Check out this website. It has set by set instructions on how to set change the NAT type to open. You have to open certain ports for xbox live which are also listed.
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614/Xbox_Live_360.htm
Sep 15, 2010 | NetGear WGR614 Wireless Router
Set NAT to open for Xbox only, not computers
This is entirely not the issue for NAT setting's . In this case we have to open the port numbers on the router to get the successful connection test.
The port numbers will be given by the Microsoft support services . Once we have the port numbers and the Ip of the Xbox following steps can be taken to enter the given numbers:-
1)Open the router gui with 192.168.1.1 or http://routerlogin.net by typing it in the address bar for the user name as admin and password as the word password only.
2)On the Netgear smart wizard .left hand side you will find a small blue/purple column with different categories , look for the one that says advanced and click on port forwarding/port triggering and select port forwarding from there and click on Add custom service from the bottom .
3)A new screen will appear which will have the following options:-
Service name:-
Service type:-tcp , udp , tcp/udp
Starting port:-
Ending Port:-
Server Ip Address:-(enter the value in range) and apply the setting's.
The value for the starting and ending port will be same i.e if suppose we have a port no. 80 for the ip:-192.168.1.15 and tcp as the service to open then this is how it will be done:-
Service name:-abc
Service type:-tcp
Starting port:-80
Ending Port:-80
Server Ip Address:-192.168.1.15
Go for the connection test after forwarding all the port numbers.
Nov 14, 2009 | NetGear WGR614 54Mbps Wireless Router...
How to set my xbox360s NAT to OPEN Witha netgear WGR614v7 Router?
Basically you have to open the application port of XBOX on your router. To do that you have to access the router's GUI and forward the ports. To access the router go to http://192.168.1.1 username is admin and password is password by default, click the port forwarding tab and open this ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Click add customer service and type xbox for service name and the IP address of the xbox.
    Jun 30, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
    Nat ports
    Go to the port range forwarding page on your router's setup.
    It will ask you for the specific port. (88,3074) Enter them in in their own seperate sections. Then select either UDP of TCP for each. Then save the settings and you should be good to go.
    Apr 06, 2008 | NetGear WGR614 Router
    NAt Settings
    Are you sure that you are forwarding the correct ports? I also have xbox live, and it seems the closer my router is to my xbox, the better the NAT gets. (wierd) Honstly though, unless you are encountering some extreme lag, I wouldnt worry about it.
    Apr 04, 2008 | NetGear WGR614 54Mbps Wireless Router...
    Netgear wireless router
    I'm trying to change my Nat settings from Strict to open so that I can play Xbox live more efficent. I tried using port forwarding but it didn't work.
    Apr 03, 2008 | NetGear WGR614 54Mbps Wireless Router...
    How do i get NAT OPEN
    To get the NAT open, you have to forward specific ports. If you are doing this for xbox live, then call microsoft and ask for an "agent." Tell them that when you test your xbox live connection, your NAT is strict or moderate. They will give you a specific port to open. With that information, You go to your router's setup, and look for port fange forwarding. Enter the information given and save it. For further assistance, call netgear's help line and they will help you.
    Mar 31, 2008 | NetGear WGR614 Wireless Router
    Nat
    reserve the ip for ur xbox in ur router settings
    do port forwarding
    and open the ports numbers of ur xbox for the reserved ip
    Feb 08, 2008 | NetGear WGR614 Wireless Router
    Xbox 360 live and netgear WGR614
    Down load the new firmware and install it in your router.
    http://kbserver.netgear.com/products/WGR614.asp
    Use UPnP. If your router supports this. Turn it on. The router will work out the ports it needs to open for Xbox live. If your router does not have this feature, check the manufacturers website for the latest firmware. (also make sure portforwarding and/or DMZ is turned off as they interfere with UPnP)
    Oct 16, 2007 | NetGear WGR614 Wireless Router
    Nat settings on netgear wgr614 wireless router
    Hello --
    Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
    This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
    After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
    Oct 15, 2007 | NetGear WGR614 Wireless Router
    Belkin (F5D5231-4) Router Logo
    309 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
