Question about Ovens
Oven - Very bad gas smell
Oven has a very bad odor of gas. Just started happening the other night. Checked the gas line and the back of the unit and nothing coming from there. The top burners work just fine. Most of the smell comes from the oven itself. Oven is only 1 yr old and just out of warranty.
  • Anonymous May 13, 2009
    When I turn on oven to pre-heat the smell of gas of so strong..
    my oven does heat up and smell goes away later..
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Is your range on natural or LP gas? What area of the country are you located in?
  • 95 Answers
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Posted on Jan 07, 2009
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Maytag Ovens
I try to start my oven and nothing happens the pilot light doesn't even come on.
Just because it glows that does not mean it is not bad...
heatman101
Sep 04, 2010 | Maytag CWG3600A Gas Single Oven
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Jul 02, 2010 | Ovens
When I first turn on the oven I can smell gas. This just started so I don't that it is a leak at a gas line connection poin. It must have something to do with an internal valve.
Have the Glow bar ignition, thermocouple and gas regulator valve checked. It is not un-common for some gas smell as the Glowbar heats the thermocouple bulb.
This in turn when reaching the correct temperature activates the gas regulator. If the Glow bar is not providing ignition quick enough. More gas can be released before combustion is initiated. This extra can be the smell you are experiencing now.
Best to have the unit serviced by a qualified technician to be safe.
Good luck Luck be safe!
Nov 26, 2009 | Maytag CWG3100A Gas Single Oven
When I turned on my frigidaire oven today I smelled a strong odor of gas, I never smelled that before. The oven is about 6 years old.
Have it checked immediately for a leaking gas line in your oven. The situation is very dangerous, gas accu-
mulation can explode and cause fire. Get is touch
for a technician immediately.
Sep 24, 2009 | Ovens
How do you light a gas oven
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Jan 11, 2009 | Amana AOGD2750 Gas Double Oven
Ovens Logo
171 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
