Home | Sony | VAIO PCV-RX753 PC Desktop | Error when loading win...
Sony VAIO PCV-RX753 PC Desktop
Problem for Sony VAIO PCV-RX753 PC Desktop
Error when loading windows
By howardlaurie on Jan 07, 2009
The hard drive has been cleaned with a shredder program and in the process of reloading windows from the Sony recovery CD I get the error "cannot normally execute the initial setting of partition information, this utility exits and your computer is rebooted"
I thought maybe a virus had partitioned my hard drive so I also tried a new hard drive and when loading the Hard Drive software that came with it I got the error "int 13 level communications: attempting int IO to drive 80 no response" then "ata level communications attempting pm ata identify" the system freezes from there. I initally thought i had a drive issue but with both drives showing errors I am wondering about a motherboard issue.
Thanks in advance for any input
Howard
Comments:
Jan 26, 2009
- problem solved
Thank you for your help
Best Solution
posted on Jan 07, 2009
Helpful)
hi99ins
Rank: Guru
Rating: 86%, 59 votes
Your shredder may have deleted the MBR (see http://www.geocities.com/thestarman3/asm/mbr/BootToolsRefs.htm for repair tools)
Also the disk partitions may not be recovered by your cd so they will have to be reinstated using PartitionMagic or, if you know how to use it, fdisk in c:\windows\command
Check your disk controller settings and drive types in the setup screen available before booting.
The software is unable to read/write to the drives possibly because of a drive type error or the type of interface selected for the controller in setup.
ATA33 drives have problems on ATA66 settings etc....
If your motherboard was failing it would not correctly select the drive types at boot. It would report
DRIVE C: <none>
and u would get a boot failure.
If you got as far as the setup for your recovery CD I would be surprised if the motherboard was failing.
Swap your DVD to the old Drive cable and try to boot from it. If the controller on the motherboard is bad it wont boot.
Check your cables for damage too..
Hope this helps
Comments:
Jan 07, 2009
- Your shredder may have deleted the MBR (see http://www.geocities.com/thestarman3/asm/mbr/BootToolsRefs.htm for repair tools)
DRIVE C: <none>
Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO PCV-RX753 PC Desktop
Questions and Unsolved Problems for Sony VAIO PCV-RX753 PC Desktop
Do you recommend Sony VAIO PCV-RX753 PC Desktop?
Answer
Answer
unable to burn music from windows media player to a disc.can only burn as a data disc.songs will... (More)
Answer
I bought the hp slimline s3707c a few months ago and I love it! But due to me being a huge gamer I... (More)
Answer
will run cd but not dvd asus DRW-24B1ST
Answer
why cant i use my spellcheck? it tells me that it no longer has english
Answer
How do I connect hP e9240 to direct tv to use my multimedia software
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony VAIO PCV-RX753 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
