Question about Panasonic WV-CP244 Fixed Color Camera
Trying to hookup my wv-cp234 panasonic ccd sec cam onto a new house, outside. Still no picture, believe it's because I didn't use wire that included a ground. will any greater then 24AWG pos/neg/grd shielded wire work, I bought some at lowes. thanks. jeff.
  • WirelessGreg
    WirelessGreg May 11, 2010
    If you don't have the manual for that camera, here is a link:
    http://www.broadcaststore.com/pdf/model/...
  • WirelessGreg
    24AWG is too small for any runs longer than ~50'. You only need 2 wires for power and 1 video coax. Does the camera work OK with a short wire close to the video monitor (or DVR)?
    Did a power supply come with the camera or did you purchase that separately? You need the 24VAC supply for your model.
    How long is the wire run from the camera to your video monitor?
    What are you using as a video monitor?
  • 423 Answers
Are you getting anything from the camera at all? Put a meter at the camera end and make sure your getting 24 volts at the cam. If you don't have 24 volts at the camera, check the fuse for your power supply, you may have accidentally crossed your wires.
Posted on Feb 15, 2009
Changing power cord from 3 wire connection to 4 wire connection
Hi jdebesch
Go to the following webpage and the pictures will show you how to convert you or 3 wire to a 4 wire connection.
I believe this is what your looking for
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Nov 25, 2012 | Hotpoint Dryers
Panasonic lumix tz8 takes white photos
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 03, 2012 | Panasonic Lumix DMC-TZ2 Digital Camera
My Nikon Coolpix P7000 consistently takes pictures that have a definiteyelliw-green tint. This happens in all different lighting settings including outside. Is this a common problem in the P7000 and if so,...
Hi there:
Aug 20, 2012 | Nikon COOLPIX P7000 Digital Camera
I have a panasonic tv camera model WV-71. How do i hook it up what all do I need. All I have is the camera and the cord. It has the cord where it hooks in the back and then it has the a/v part in the...
Hello! You you cannot use the camera with a vcr. This camera needs vertical drive sync impulses from a dedicated monitor. The video signal, the vertical sync and the video signal are sharing the same coax cable.
Best regards
Gelu
Sep 04, 2011 | Panasonic Wv-80 Wv-71 Kit Tv B/w Camera...
The screen seems not to get light from outside everything is sort of purple
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
Jun 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
How to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
Jan 08, 2010 | Panasonic WJ-HD316/6500 Series 16 Channel...
I am having an issue getting a clear picture with the Panasonic WV-CP254 using the Panasonic WV-LA2R8C3B Lens, 1/3``, AI, F1.3, 2.8mm Super WA. This is a new install and I followed the instructions for set...
My Samsung Digimax A5 is not staying on with new batteries fitted ?
I have used this camera for 3 years...never had a problem.
It's Digimax A5 / A53
Please e-mail me
jerry_elena5@hotmail.com
Jul 22, 2008 | Cameras
Camera turns on, but LCD screen is black
Solution: Turn the camera on. Put it into camera mode so the lens opens. Then push up on the underside of the lens, you'll see the screen light up and it can now take pictures. This worked for me for a month or two. The problem is that I have to keep pushing harder and harder to get it to turn on, and now it turns back off as soon as I stop pushing. So I have to get a new camera. This is a widespread problem with this camera. I previously paid Panasonic the $162 to fix the zoom freezing up. I'm not paying again.
Dan
May 30, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Used camera
cant say any thing about that. if the camera is not repaired, working condition, not very old, giving few months warranty, giving good price, etc. then i think you can buy otherwise i dont think so.
Jan 30, 2008 | Panasonic WV-CP244 Fixed Color Camera
Wv-cp234 panasonic security camera
Sounds like the iris is staying open.
You need to switch the bottom dip switch the other way
The switches are, from top to bottom:
  1. Sync selection switch (LL/INT)
  2. Electronic Light Control/Automatic Light Control selection switch (ELC/ALC)
  3. Detail level selection switch (SOFT/SHARP)
  4. Back light compensation on/off switch (BLC on/off)
  5. Lens selection switch (VIDEO/DC)
Sep 05, 2007 | Panasonic WV-CP244 Fixed Color Camera
Panasonic WV-CP244 Fixed Color Camera Logo
514 people viewed this question
Top Panasonic Home Security Experts
Lawrence Oravetz
Are you a Panasonic Home Security Expert? Answer questions, earn points and help others
