SOURCE: Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
SOURCE: ice maker don't make ice, the three red lights just keep on blink
Hello, my name is Victoria and I am a representative of Greenway Home Products. Sorry to hear you are having some troubles with the ice maker! Feel free to call 1-866-253-0447 to speak with our customer service rep to discuss how we can fix this for you. If you would like you can also email me directly at [email protected] and I can help you further. Hope this helps!
Victoria
SOURCE: Ice cream machine was making ice cream and now the
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
SOURCE: don't have instruction manual. How do you
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
