Question about ALR 3Y Power Technology 300Watt 7300 Series (YM3321A) Power Supply
I am looking to have multiple power supplys repaired. Do you guys do this? 3y and Delta power supplys
You can visit below link to get the power supply.  Johnny
http://app.arrownac.com/aws/pg_webc?s=P
Posted on Apr 02, 2009
  • 33 Answers
Generally power supplies are difficult to fix if something's wrong, and it probably would cost more than they're worth. You're better to just spend the money on new ones. They aren't too expensive to replace. Unless it's something visible on the outside like a fraying wire or a broken connector, which can be fixed with a bit of solder and shrink tube or maybe an extra connector, you're better off replacing than repairing.
Posted on Jan 07, 2009
1985 Toyota hilux yn65 3y engine what are head bolt torque specs and If the 3y has strech head bolts
14mm bolts 65lbs and the 12 mm bolts 14lbs tighten in multiple passes low to high as far as the bolts being strech to torque they are not but should probably be changed due to age
Nov 18, 2017 | Toyota Cars & Trucks
WHAT ARE THE CRANKSHAFT BEARING CLEARANCES ON A TOYOTA 3Y ENGINE
.002 is fine. You need that clearance for oil to fill in between the crankshaft and the bearing.
Nov 28, 2013 | Toyota Cars & Trucks
(2x+3y)(3x+2y)
(2x - 3y)(3x + 2y) = 2x*3x + 2x*2y - 3y*3x - 3y*2y
= 6x^2 + 4xy - 9xy - 6y^2
= 6x^2 - 5xy - 6y^2 You multiply each element in the first set of brackets by each element in the second set of brackets and then consolidate like terms and arrange them in sequence of powers, first x and then y. So:
2x by 3x = 6x squared
2x by 2y = 4xy
-3y by 3x = -9xy
-3y by 2y = 6y squared
6x squared -5xy + 6y squared
Dec 04, 2010 | Yahoo Computers & Internet
How do I solve x and y in the following equations? 5x+3y=6 2x-4y=5 Thank you
You can solve it with following method.
5x+3y=6 2x-4y=5
So 5x=6-3y so 2[(6-3y)/5]-4y=5
So x=(6-3y)/5 so 12-6y-20y=25
so -26y=25-12
so -26y=13
so y= -(1/2)
2x-4y=5
so 2x=5+4y
so 2x=5+4(-1/2)
so 2x=(10-4)/2
so 2x=6/4
so x =3/2
The value of x=3/2 and value of y= -1/2
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 03, 2010 | Office Equipment & Supplies
Need schematic for 3Y model YH-1361A
No Schematic was available from y'all so I check another unit for the part value I needed to find. Thanks
Nov 10, 2009 | ALR 3Y Power Technology 300Watt 7300...
I get sound, can change the channels, etc, but my Polaroid television screen has no picture whatsoever; it's just a black screen.
lubbarlubab, Looks like you will need to get a power supply repaired/replaced in your unit. Before you call out the service guy, you should spend 30-40minutes at YOUTUBE and view some "LCD-TV repair" videos and also videos of "LCD monitor repair" and LEARN what are the most common components that are causing this plague of "BLACK SCREEN of DEATH" to disrupt your life. If the "cold-cathode-fluorescent-lamps" fail to light-up due to a failure of a single or multiple $2 parts on a power supply board you have a black screen!! This problem is also very common to LCD computer monitors. Try to view a vid by someone called "cal22583" who did his own repair to a Philips 42" or 50" unit. If this was of some help please rate on fixya.
Bye for now. 12fixlouie
Nov 08, 2009 | Zenith L13V36 13" Flat Panel LCD Monitor
4x+3y=6 how do you solve for y
I am not lecturing you but I would rather you understand how to do the manipulations involved in isolating a variable.
You want to isolate y, Ok
Start stripping it of all that is not y.
3y + 4x =6. (Addition is commutative, I can change the order of addition)
The term with y is added to 4x. If I want the term in y alone on one side I perform the inverse operation of addition, a substraction. I subtract 4x from both sides.
3y+4x-4x=6-4x. But 4x-4x=0, and we are left with
3y= - 4x+6
This operation is sometimes summarized as make one term change side while changing its sign
It would do no harm to put the right side of the foregoing equation in parentheses. I do that to avoid errors)
3y= (-4x+6).
Now y is multiplied by the number 3. To isolate y I have to perform the inverse operation of the multiplication, namely the division by 3
3y/3 =(-4x+6)/3. The left hand side is just y
y= (-4x+6)/3.
While result is correct, I can also open the parentheses
y= -4x/3 +6/3
y= -(4/3)*x +2.
Hope it helps.
Oct 22, 2009 | Texas Instruments TI-89 Calculator
Computers & Internet Logo
63 people viewed this question
Top ALR Computers & Internet Experts
David Payne
David Payne
Are you an ALR Computer and Internet Expert? Answer questions, earn points and help others
