Question about Dryers
Squeeking noise when drying
There is a squeeking noise coming from my dryer it is not a constant noise. I think i just need to lub the gears and pulleys but cant find access.
  • skrappy98 Jan 07, 2009
    kenmore 110.78652700
  • Phil Brantley
    Phil Brantley May 11, 2010
    What is the model number , it should be in the door jam of the dryer.
  • 242 Answers
You have a whirlpool made kenmore dryer , there are 3 moving parts that can be making this noise , the belt tensioner and 2 wheels that the drum rolls on .
to get to these parts you go into the front of the unit. start by removing the 2 screws on the top where the lint screen inserts. then get a flat screwdriver to pry the top of the dryer away from the door panel it should have clips holding it down on both sides of the front.
after that you can see the drum with the top open like a hood of a car , look inside there are 2 screws holding each corner of the front of the dryer , they are 5/16 hex heads , remove these screws and the entire front door panel will come loose , pull the panel upward to release the lower clips holding it.
Now that this panel is removed look under the drum to see how the belt is held so you can put it back correctly , after removing the belt pull the dr om out and you will see the wheels , you can use motor oil to oil the center of the wheels and the belt tensioner. to get the drum back in set it on the wheels and roll it untill it falls into place and reassemble the rest if you have any other questions let me know and tell me how it works out.
Phil
Posted on Jan 07, 2009
  • Dryers Master
  • 8,220 Answers
mounts on rear drum bearing
of GE/Hotpoint dryer
  • Dan Webster
    Dan Webster Jan 07, 2009
    WE3X75 less than 10 bucks
  • Dan Webster
    Disregard my post. Phil is correct. I was going on the assumption you has a GE dryer. My bad.
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
My dryer squeeks while it's running. How do I get into the dryer to lub the belt.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
It is making a loud squeeking noise when drying. I think that it is the bearings. How do i replace them from the front or back of the dryer.
you replace from the front but this dryer has no bearing. It has glides or rollers and idler pully. you need to take it about and check out these parts. replace the ones you need to.
Nov 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Constant squeeking while drying clothes
It's most likely the roller bushigs/axles which need lubricating -- they've probably not failed yet, but will if ignored.
They squeak more when clothes are wet because of more weight.
I'd also lubricate the motor while your in there.
May 08, 2009 | Dryers
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Dryers Logo
208 people viewed this question
Top Dryers Experts
