How would I connect a recently purchased Onkyo M 282 amplifier to a Yamaha RX-V663 reciever to power speakers in a second room
  • 2 more comments
  • mfile3 Jan 07, 2009
    the back of the amplifier has RCA in
    RCA out
    1 speaker left connection 1 speaker right connection
    How do I go from the reciever out to the amp and from the amp to the second room speakers
    Please be specific
    the back of the amplifier has RCA in RCA out 1 speaker left connection 1 speaker right connection
    How do I go from the reciever out to the amp and from the amp to the second room speakers Please be specific
    specifically where do the phono jacks connect on the reciever and I assume they plug into the in on the amp
    speakers are wired with a volume control in the room
  • 19,396 Answers
Posted on Jan 09, 2009
    Novelist:
  • 123 Answers
Using a HDMI cable available in all TV stores, connect the output HDMI socket on the receiver to the input HDMI on the amplifier. Run cable to your other room for the speakers. Connect the speakers (observing polarity red-red black-black) to the speaker wire, connect the other end in the other room to the back of the amplifier speaker-out sockets.
Plug both units in and tune the receiver.
Note,your amplifier has no volume control but you may be able to control it from the receiver. The manual for the receiver should explain how to adjust the output level of the HDMI socket
Hope that works out for you...:)
Posted on Jan 07, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, You should connect audio out of the Yamaha to Audio in (back side) of the Onkyo amplifier.
  • 716 Answers
From The Device The Sound Is Coming From Hook Up To Rca Jacks Output To The Second Device Hook Into The Rca Jacks Input. If There Is No Rca Jack Input You Can Buy Connectors From Radio Shack And Turn Them Into The Specified End You Need.
  • Michael Fisher
    Michael Fisher Jan 07, 2009
    Ive Checked Your Devices And Your Gonna Wanna Come Out Of Your Onkyo M 282 rear Bottom Left
    Where It Says Audio hook into botch connectors on the right. Then On Your RX-V663 rear Bottom Left Phono In Hook Up The Other 2 Ends.
    Genius:
  • 1,199 Answers
Go to this link and it will show you how to hook up steo by step
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070
    Scholar:
  • 76 Answers
The Yamaha RX-v663 apears to have a 95 watt output, and the Onkyo 100 x2. The Onkyo does allow pass through, so I would read the set up instructions of the Yamaha if you need to connect them together for mult-room control.
Here's a link to the configuration from Yamaha
Good luck and let me know if this helped
  • 10,594 Answers
Hook RCA cable in Onkyo line in and other end of cable will go to line-out / monitor in Yamaha. Onkyo will receive Yamaha out signal and will drive its own speakers in other room.
    Sergeant:
    Champion:
  • 304 Answers
The first step is to determine where and how you will run the speaker wires from the receiver to the speakers. In most cases, the wires will run on the floor along the baseboards. Measure the distance between the receiver and speakers and make sure you have enough speaker wire.
Connect the left and right channel speaker wires to the ‘Main’ or ‘Front’ speaker outputs on the back panel of the receiver or amplifier, then run the wires to the terminals on the back of each speaker. Make sure you connect the left channel output of the receiver to the left channel speaker and the same for the right channel. Correct speaker phasing is very important for the best sound. Read more here about correct speaker phasing.
  • Elizabeth Krijt
    Elizabeth Krijt Jan 07, 2009
    You must have a pre-amp output for connection of an external amplifier.
    If you don't have such an output on an existing receiver, you'll
    probably need to upgrade that as well if you'd like to use an external
    amplifier
  • 15,935 Answers
Output from Source (dvd, tuner, etc) to the input on the amplifier using RCA cables.
Speakers go to the ampifier terminals
  • 4 more comments
  • blueextc3221
    blueextc3221 Jan 07, 2009
    Component RCAs (Red & White) From Source (dvd, tuner cd etc) OUT on Reciever to IN on amplifier
    Flip switch to AUDIO (for signal sensing and auto turn-on)
    Speakers attach to +/- terminals accordingly.
  • blueextc3221
    http://i3.photobucket.com/albums/y66/Leu...
    this is all you will need.
    Then from the amplifier, speaker wire to the speakers in the other room.
  • blueextc3221
    Red to red, white to white - on back of reciever... you have to select which source you want to use.... CD, DVD, Tuner etc.
    Then the other end of the cable goes to IN on the amplifier.
    Then to hear the music in the other room, you must select the source (dvd, cd, tuner). The auto switch on the amplifier will sense an audio voltage thru the cable and turn on.... and your speakers will be playing in the other room.
  • blueextc3221
    example:
    i want to play the music from the radio in another room.
    I connect red/white RCAs to the OUT on the back that says TUNER.
    Now I take the other end of the cable and they go in the Red and White of the IN on the amplifier.
    I run my speaker wires to the amplifier
    And finally switch the small switch to the right of the red& white RCAs to Auto.
    Now when I want to listen to the Radio in the other room... i select TUNER on the face of the radio or remote.
    The amplifier sesnses the voltage thru the RCAs and turns on, and then amplifies the signal from the tuner to the speakers connected to it.
    Hope this helps.
  • blueextc3221
    the volume control is a potentiometer that only limits the signal going to the speakers. You can use that as a remote volume knob.
  • blueextc3221
    The Zone 2 pre-out should be a good signal... but im not sure if that will be from all sources or not.
    I am looking at the rear of the reciever, but it is hard to make out.
    All the outputs are on the right side.
    You are looking for an output.
    Front, Zone, Rear (not subwoofer).
    Sergeant:
    Scholar:
  • 199 Answers
You will require a cable and the adapters to connect them.that cables you can get at  radio shack websites.
  • 679 Answers
The sppeakers are wireless or with cable?
  • 4,806 Answers
Hi there
You will need to purchase a set of phono jack leads to connect the amp to the receiver
Good luck and kind regards
    Genius:
  • 1,550 Answers
Connect left and right channel speaker wires to the ‘Front’ speaker outputs on the back panel of the receiver or amplifier
I have connected a cordless microphone to RX-V663 but there is no output in speakers? Do I have to make changes to amplifier or select out some outputs?
How did you 'connect' the cordless microphone to the RX-V663? You will need to select this same input in order to get output in the speakers.
Sep 25, 2014 | Yamaha Rx V663 7.2 Channel 665 Watt...
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
Can i use panasonic SB-AK57 speaker (6 ohm) with yamaha system RX-V663 (8 ohm) ?
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
Apr 25, 2009 | Yamaha NS-A60X Main / Stereo Speaker
Trying to hook up Zone B stereo speakers in two additional rooms.
The infrared mentioned by the manual is most likely an extension possibility to use the remote control in each room, forget that part.
What you need to do is quite simpel, after connecting all speakers, you should indicate in the setup menu of each zone which speakers are connected and do as follows:
in main room select 5.1 setup, for the other zone select only the left and right front speakers.
Your EXTRA SP indicates the extra speakers for 7.1 setup and when set to zone B it recognises only 1 speaker.
So read carefully the manual how to connect Zone 2 speakers and connect that way, than carefully walk through the setup menu to setup the zone 2 correctly.
Apr 09, 2009 | Yamaha RX-V663 Receiver
Voices drowned out by background noise.
Not a suggestion, but I hope there is a solution.
Recently bought an LG HDTV that has a setting that should increase the voice over the background. If it does, I can't notice the difference. I guess they can probably measure it electronic.
I've had your same complaint for years, without a good solution. Best so far is to use headphones.
I have no idea why film people add all the extra noise. Most of it is not even real.
Dec 29, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 delays 10-30 seconds between commands using the remote control. New batteries, new receive. For example, try to raise volume. It goes up 1 dB then cannot give any other commands using the...
I have seen this type of thing with several remotes.  You have some light source in the room that is interfering with the reception of the ir.  Turn off all light sources in the room and then try.  You might be surprised!
Dec 20, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
 Grubhead
Grubhead
