Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi 65" Rear Projection
All the sudden my display automatically switches from standard to expanded view. I reset to factory defaults and the issue still occurs. Unplugged overnight and problem still occurs. DVD's cable doesn't matter. No signal input at all and it just starts switching. Tech coming in a week. Any help is greatly appreciate it.
  • montgom Feb 23, 2008
    our t.v model #ws 65869 start blinking and we couldn't stop or start the re set button,if some one knows how to fix it we took the DMP board and check 4 shortage none we think it might be the lamp
    Sergeant:
    Champion:
  • 301 Answers
Possibly bad buttons. unplug the connector ZF behind the speaker grill of the tv. you might need to take the panel off behind the grill to get to the connector. if your problem ceases then you most likely have bad buttons intermittently shorting.
Posted on Feb 20, 2008
How to reset factory settings ws 65517
If you contact Mitsubishi the set has three hidden menus---convergence adjust, circuit adjust and OPTION MENU.
Each model uses a four digit code with menu and for example 4750 and in the Option menu is the option to do the hard reset for the set---
The wipes all labels (dvd etc) and puts set back to default on all factory settings.
You might find it if you GOOGLE THE MODEL NUMBER with option menu after it...........
Mar 18, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi Ws -65313 65in
Follow the steps below to reset system defaults to factory settings. . Press the MENU button followed by number buttons , ,and on the remote control. Result: The above steps activate the Reset System Defaults menu screen . Press the ENTER button on the remote control. Result : The settings reset to factory defaults. . Press the HOME or MENU button on the remote control to return to the HOME or MENU screeen. IMPORTANT: This function is not recommended unless it is mandatory to reset system defaults to factory settings. This operation CANNOT be undone and all customs settings will be erased.
If you are unable todo that id suggest you contact Mitsubishi, your dealer, or a local professional.
Main support number 800-332-2119
Support FAX (714) 229-3854
Email supportCustomerCare@meus.mea.com
Mar 30, 2008 | Mitsubishi WS-65313 65" Rear Projection...
I turn it on and only get a blue screen.
go to menu and to net link and reset to factory defaults
Feb 03, 2010 | Mitsubishi WS-65713 65" Rear Projection...
My tv change format size from expand and standard on it own. How can I solve this problem?
My 65" Mitsubishi just started this as well. Any updates? Repair or time to get a new set?
Nov 08, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Will not stay on., Automatically turns off.
Try pressing in both the menu and device/input buttons in together on the front of the set and hold for 5 seconds to see if the led will blink a two digit error code such as 2 blinks then a pause then two more blinks followed by a pause which would indicate a 22 error. Then let me know what the blink code was if any.
May 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Red convergence problem - Mitsubishi 65
It sounds like your red gun might be close to going, we had the same problem our tv. The red was off and couldnt really be adjusted but the others were alright. We were told that the red gun was nearing the end of its life and it could cost upwards of $1000 to fix, so we just got a new tv. i would suggest having a tv tech come out and look just to make sure, but thats wut it sounds like.
Oct 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Format Change
there may be a setting in the menu that you have to turn off to stop this
Jul 21, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Focus
Use the Setup menu to select English or Spanish as
the language for the menus and on-screen displays.
Adjust Color Balance Automatically or manually
(PerfectColor TM) using six colors, Magenta, Red, Yellow,
Green, Cyan and Blue. Reset the Color Balance to the
factory default settings. Align the focus (convergence)
of the TV's projected light beams or reset the focus to
the factory default settings.
Jul 01, 2008 | Mitsubishi WS-65515 65" TV
Red Color Across top of TV
you need to the convergence IC this is an easy repair and you can get the replacement IC at the following link and they provide installation instructions and free online tech support while you do the repair it saves you a 400.00 repair bill for an hour job. The IC you need is number STK393-110. Heres the link.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65807 problems
You need the two convergence IC's replaced part# STK392-570. About a $300-$400 repair.
Aug 23, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
