  • 8,637 Answers
Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Error code 0x610000f6.. would this be related to refiled cartridges
Hi paschal karl
The error code you are seeing may or may not have to do with the cartridges being refilled.
Here's the thing, yes, you can refill your cartridges or use re manufactured cartridges, but you may run into problems.
QualityLogic, one of the world's foremost quality assurance organizations, tested the performance of HP inkjet print cartridges vs. re manufactured (refilled) brands. The results: original HP inkjet print cartridges far surpassed ink refills in both print quality and reliability.
  • Nearly one out of every six refilled ink cartridges tested was dead on arrival or failed prematurely
  • 70% of refilled cartridges had some form of reliability problem
Count on HP original ink cartridges for consistent, worry-free printing. You may think you're saving money on re manufactured or refilled ink cartridges, but in the long run, the cost of wasted time, ink, and paper can more than make up the difference. -Source
Most people think, 'well of course that is what HP or an HP representative would say', but I have done some research and found that many others have too. Here is a perfect example of somebody who does not work for HP in any way and basically is a customer advocate (in my opinion) ;Should you refill your printer's ink cartridges? HP says no (of course) By Matthew Murray
I found the above article interesting and genuine.
To summarize, again, yes you can refill the cartridges. The printer is not programmed to reject them. Sometimes the cartridges will not work and of course because they are non HP, HP would not be able to do anything to help. HP cartridges have a 2 year manufacture warranty;Limited Warranty for HP Ink Cartridges and Customer-Replaceable Printheads for HP Inkjet Supplies, this may give you comfort knowing HP stand behind their product.
Perhaps you will find the following document helpful:
HP Printers Problem with Printhead Printer Failure Ink System Failure or...
I hope this helps.
I work on behalf of HP.
Jun 23, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Non-recognised ink cartridge
I haven't tried the Colour/B&W/Stop button combination suggested above, but on a Canon MG5250, switching off, then on, and immediately holding down the 'stop' button for 20-30 secs does seem to disable the block. After that the colour concerned has no indicator. It seems that refilled cartridges will woork for a few refills (showing low ink on the indicator) before requiring the permanent fix.
Jun 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
After refill computer says no ink and i checked the ink is full how can i reset the computer to tell it is full
unfortunately you can not reset it. If you refilled your cartridge rather than replacing it then its very possible the print head on the cartridge is damged and no longer working. Its best to either refill a cartridge once or not at all. The print heads on the cartridge are not desinged for that type of use. If a replacement cartridge doesnt fix the problem then you probably have a bad print head inside the printer.
Nov 18, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
Refilled cartridge, still says it needs to be replaced...
If you let the cartridge run totally dry then they need to be reset or replaced, I have tried purchasing reset software myself and found then to be a waist of money as they do not reset the cartridge at all. Do yourself a favor and replace the cartridge and remember to top up the cartridges before they get half empty.
May 08, 2009 | Lexmark X2600 InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 5070 printer
Hard to tell...There are other issues which could contribute related to the printer itself, etc.
But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
Jul 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
Refilling cartridge
cucujo, you were not as lucky as lovetofish! Sooner or later the printer will win.
The money for printer manufactures is not in the printer, it's in the ink refills. With this in mind many printer Mfg's have added small chips to their ink cartridges. These chips track the amount of times the printer prints. The software knows you are adding ink to the cartridges. Many people find they can get around this by keeping their old cartridges & refilling. Some HP users keep as many old cartridges as three. Rotating ink cartridges. This seems to work for most printers. Suggest you try the same. Continue to fill you're ink cartridge but replace with a new cartridge. When it empties replace with another new. The next three will be re-filled ink cartridges. Always refill as soon as possible, never turn ink cartridges on their sides. Keep refilled cartridges in an airless zip-lock bag, in a cool & dark place when storing.
May 05, 2008 | Lexmark X3550 All-In-One Printer
147 people viewed this question
