Question about Crosley CDE6000 Electric Dryer
Heating element in Crosley Clothes dryer
How do you replace the heating element(s) in a Crosley dryer? How do you get to it also?
  • Anonymous Nov 12, 2007
    My dryer is getting warm, but not hot enough to dry the clothes. What trouble shooting steps do I need to take?
  • Anonymous Apr 26, 2008
    want heat
    Scholar:
  • 125 Answers
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
Posted on May 30, 2007
  • 883 Answers
Back panel. look for small sheet metal screws and disassemble metal panels (and possibly drum shaft bushings) until coil is seen.
Where is the heating element in my crosley clothes dryer
Posted on Nov 05, 2012
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Posted on Oct 25, 2007
TheMobilian
  • 8220 Answers
SOURCE: Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Crosley CDE 7000 dryer that stopped heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 06, 2010
My dryer will not heat up
Could be switch broken, heater elements or wiring broken.
Nov 06, 2014 | Crosley Dryer Heater Element Replacement...
Where is heating element in crosley clothes dryer
What is the model number of the unit?
Nov 05, 2012 | Crosley Dryers
My dryer turns on and runs but the clothes are not drying. its a crosley dryer and relatively new. checked lint filter and vaccumed up dust and lint and made sure that the screen and exhaust were clear
Sounds like the heating element or a fuse for the heating element. Impossible to tell you how to troubleshoot though unless I have the model type. Use google to type in your type and model number along with heating element (i.e., GE XXXXXX heating element troubleshooting) and you'll likely find some instructions for troubleshooting.
Sep 07, 2011 | Dryers
Crosley dryer will not turn on - worked fine one day and now will not work - suspect electrical switch but which one?
The thing that kills these dryers is lint and bad blower wheel. The lint causes excess heat in these dryers and that melts the blower wheel hub and it begins to slip. This makes the clothes take twice as long to dry and eventually trips the small thermal fuse mounted beside the heating element. themobilian_594.jpgthemobilian_595.jpg
Go ahead and remove the front panelthemobilian_596.jpgthemobilian_597.jpg More HERE
Dec 28, 2010 | Crosley Dryers
Crosley Dryer Model CEDX463RQ1 no heat
take elements to a dealer and have them checked, unless you have a digital multimeter and can DIY.Otherwise get a replacement element
Aug 01, 2009 | Dryers
Dryer runs and tumbles clothes but there is no heat therefore does not dry the clothes
the first thing to check is heating element if it checks good then it will be the thermostat
May 09, 2009 | Crosley CDE6000 Electric Dryer
Electric Dryer, heating el works, exh not blocked, clothes no dry
double check your element temp t-stat and recheck continuity on element. I have known them to work but have shorts in them
Apr 09, 2009 | Crosley CDE6000 Electric Dryer
No heat not drying clothes
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
Apr 02, 2009 | Crosley Dryers
Crosley CDE6000 Electric Dryer Logo
1,863 people viewed this question
Top Crosley Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
