Question about Faema FA60081
Need operator's manual for Faema C85/1 espresso machine
The brain on our old machine fried and we bought a used one at a yard sale. We cannot figure out how to operate it, and were wondering if there are any online instruction manuals. Specifically we cannot figure out how to get water into the reservoir.
  • Sulejman Sulejmani
    Sulejman Sulejmani May 11, 2010
    1. wich model of faema you have
    2. the vater level controler(brain) is it universal one or it is for Faema only,
    3. did you check the solenoid valve, does she open for filing
    4. did you tryed manualy to fill? can you fill it manualy?
SOURCE: User Manual
Please email me tomorrow at dspringer5114@hotmail.com. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
Posted on Jun 01, 2008
EsWorld
  • 1618 Answers
SOURCE: espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Posted on Apr 28, 2009
EsWorld
  • 1618 Answers
SOURCE: User Manual for Faema D92/A, doesn't dispense coffee, only water
This will take some time so bear with me.
The problem with the machine is most likely the solenoid valve(black or blue electrical box connected on the side of the group), for easier access remove the front panel there are about 5 screws holding it in place, 2 on the bottom and 3 on the top under-side. Disconnect or turn off the water supply. Then using a 14mm open end wrench remove the nut and the discharge pipe. Do Not remove the 4 small allen wrench screws on the brass piece connected to the machine. Now remove the electrical box over the silver pipe, and using a cressent remove the silver pipe from the brass rectangle square. Slowly open the water supply, if water shoots out then the head is clear, we will move on if not, use a pin and clean the middle hole. Check the silver pipe also there is a small plunger in there press it in if it moves freely then we are good, if not you can try soaking it in puro caff until it clears or just get a new solenoid coil. Remove the shower screen and screw in the group head, you can soak those also.
If you still cannot get water, then we will have to go deeper into the machine.
Posted on Jun 03, 2009
EsWorld
  • 1618 Answers
SOURCE: How do I program the automatic dispensing portions
Press stop and the button that you are programming at hte same time, when you get the volume desired release.
Posted on Jun 09, 2009
EsWorld
  • 1618 Answers
SOURCE: we have an older faema due machine. Currently the
The tip of the steamwand is clogged or the fitting where it connects to the boiler is blocked with carbon.
Posted on Jun 20, 2009
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Feb 09, 2015 | Faema Smart A2 Automatic Espresso Machine...
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
Need a users manual in english for the faema due espresso machine
Try Googling (faema)(FA60081)(manual) without parens. You may have to refine your search to get an English version.
Oct 10, 2011 | Faema FA60081
I just purchased a Faema d92/s1. I need a operators manual and a parts. Where can I get them?
GO ON THE INTERNET AND THE BRAND NAME OF THE MACHINE. MAY
BE ABLE TO DOWNLOAD OFF INTERNET.
Sep 19, 2011 | Faema Emblema
I have a faema no stop 2 head espresso machine from 1983. how do i start the machine?
Just turn on the main on/off switch wait about 20-30 min. for the machine to get up to temperature once is ready you can use it.
To make an espresso, put the espresso in the warm portafilter and push the down oce is ready push it back up.
If you need more details, Let me know
Jan 13, 2011 | Faema FA60081
Bought a used Faema Eurostar Combi. Don't have a
If it's the same as the used one I just picked up, there is a dial position for coffee, with a little cup on it. The dial position for steam is the one that cares about the positoin of the steam/hot water button.
The coffee position will never use steam and you don't need worry about the position of the steam button if you're not frothing milk.
Jun 29, 2010 | Faema FA60081
Yard sale purchase wiht no manual. Need basic
Most of the manuals are available online at www.cuisinart.com
There is a model # located on the bottom of the coffee maker in tiny microscopic writing that is the same color as the material. Just go to the Cuisinart website and enter your model #. Or, tell us your exact model #, and we will give you a direct link to the manual.
-Tha Mp3 Doctor
Mar 04, 2009 | Cuisinart Coffee Makers & Espresso...
User Manual
dgsrgr8
May 31, 2008 | Faema Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
415 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
Kelley Hopper
pawnpower
richie46
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
