My thinkpad has 3GB RAM, but sometimes when i have 10-15 IE browser windows open, i cannot open more. It complains "short of storage", Any idea?
  • sguoibm Jan 08, 2009
    Thank you very much. I will try the way you suggested.
  • 33 Answers
Get Firefox :)
Ok, seriously, your laptop should be able to handle all those windows with 3GB of RAM. Try to get it up to that many again so you can see the error, and when that happens, open Task Manager (Ctrl+Shift+Esc). Then click the "processes" tab and click on 'Memory.' Click on it so that it's sorted with the largest numbers at the top. You should be able to see what program is taking up all your memory. I'm not sure if IE would use that much (I use Firefox... 1 window is all I need!) You may have spyware or some unwanted program leeching all of your resources and in that case I would recommend you get some antivirus or antispyware software.
Posted on Jan 07, 2009
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
BIOS says 3GB RAM, Properties says 2GB RAM
You may want to flash your bios on the motherboard if there is an update. Windows XP Pro will support up to 4GB of RAM.
Feb 20, 2013 | Microsoft Windows XP Professional
Why is my computer still lagging even after I close the game
Sounds like there is some process being run that is eating up a lot of your RAM. One thing to check is that you are using a 64-bit install of windows if you are using 32-bit it won't matter that you have 6gb as you can only use 3gb with it. It could be that you are running 32-bit and 7 is taking up about a gb of RAM while the games (even when closing) take up 2gb or so. So you could be maxing your 3gb on 32-bit.
Mar 23, 2012 | Intel Core 2 Duo E7600 Processor...
What is the max ram i can upgrade to ?
The amount of memory your Windows computer will recognize depends on two factors:
the maximum capacity your computer hardware can handle and the version of Windows your computer uses.
The most memory the 32-bit versions of Windows will see is only 3GB or 3.5GB, if your computer hardware can handle it. The 64-bit version of Windows can address even more memory.
Apr 09, 2011 | IBM ThinkPad T30 2366 Notebook
Sorry, But my IBM t42 Thinkpad with no screen has 1 long beep and 2 short beeps. I suppose those beeps mean something is not right.
This IBM beep code means a motherboard or a video fault.
The video chip is part of the motherboard.
There is one thing you can try, the video RAM uses Shared RAM (ie. it uses part of the RAM module), if the RAM is faulty or not seated properly it will produce this error code.
Re-seat the RAM module, and if it still doesn't work then take the RAM to your friendly computer/repair shop and get them to test the RAM for you. If it is faulty, then replace the RAM and with luck the laptop will be operating again.
Dec 20, 2009 | IBM ThinkPad T42 Notebook
I have the same problem
if you are using windows xp, then follow these steps:
1) right click "my computer" icon, select "advanced" tab, click settings button towards the right of "start up and recovery" and  click "edit" tab
a notepad window appears with some text in it which reads something like this :
[boot loader]
timeout=0
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
modify that text to look like this:
[boot loader]
timeout=0
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT /3GB /userva=2800 /NoExecute=Op
Warning : only the "/3GB /userva=2800 /NoExecute=Op" has to be added extra else you will mess up
2) save the notepad and insert max ram, and check, if any BSOD's
if the problem persists, then it is hardware related..
Most probably one of your ram stick may be the problem child(which may be either incompatible with your motherboard or defective)
Best of luck...
Aug 28, 2009 | Lenovo ThinkPad R51e Notebook
What is upgrad & how upgrad in HTC Touch P3450?
u cannot upgrade storage memory that is called RAM and ROM but u can always upgrade ur Storage card that is used for the storage of programs and files I understand ur problem u are feeling short of memory in Program and storage that RAM and ROM u cannot upgrade but u can do something about it i can help u in this
option 1
u can always reset the device for a new start and then try installing all ur programs to ur memory card when it ask for location where to install select storage card there and ur ROM will not be used to store those programs plus ur device will be fast in performance.
always
1.store programs in storage card
2.never install in ROM or ur device memory
3.Always close programs from the Task Manager a small arrow up on right side of screen select all programs and close them after u are done with them u will never be short of RAM.
4. Set ur History and cache folder of ur browser IE or OPERA to Storage card if u cant find the link to do this just google SKTOOLS for Windows Mobile download and install this software will let u configure where to keep ur history and cache files
5.When u recieve files from bluetooth they by default comes in the Device/MyDocuments folder and this will use ur device storage which is limited offcourse so u can google OBEX INBOX install and set the folder of recieving files thru bluetooth to memory card directly this is a very imp tool u will never find it easily i bet.
Feb 27, 2009 | HTC Touch P3450 Smartphone
OS not showing full RAM
Hi Shibbymusic, as with most Asus boards if not all! The MB
A8N-E does not show all of your 4GB memory. See this FAQ;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=A8N-E&os=17
Like you, I too have 4GB of memory.
Asus A8N32-SLI Deluxe w/4GB memory only see's 3GB
The bios displays 3GB during boot up & so does windows XP 32bit.
You might want to think about upgrading to 64bit os.
Updating your bios should help as well.
(See A8N-E Bios version 1010); http://support.asus.com/download/download.aspx?modelname=A8N-E&SLanguage=en-us
Thank you for using fixya!
Mike
Dec 07, 2008 | ASUS A8N-E Motherboard
Wireless connection works for Skype doesn't work for IE and Outlook
Hi there,dkny, What kind of router are you using? That may be where the complaint is coming from. Perhaps there is a setting to allow programs and/or hardware(wirless card). Also does the wireless card come with a configuration utility? You may have to 'tell it' what you want to do. Hope it helps!
Jun 02, 2007 | IBM ThinkPad T60 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
