Question about Monte Carlo 5AHR60OCD Arch Old Chicago Ceiling Fan
FAN STOP TURNING
LIGHTS UP THE BUTTONS ESPOND RED BUT WILL NOT TURN
    Brigadier General:
  • 8,619 Answers
Hi! try old fashioned way, take a stick and try to run the fan with it and when it catches up some speed then turn it on. Or else tap on the face plate of your fan and else check for any loose connections or any oil leak from fan's capacitor.
Posted on Jan 07, 2009
Why did fan and lights stop working?
If you are controlling lights and fan only with the remote - no problem. Once you start flipping switches, the remote control loop is broken. You can restore remote control by setting the wall switches to off, turning off power at the circuit breaker (or fuse), and waiting for a few minutes during which you will be removing the battery from the remote and pushing all buttons, then reinstalling the battery. When time is up, restore power and try the remote. If no luck, check to be sure the wall switches are set to off and repeat the routine.
Jan 28, 2016 | MinkaAire F715-STW Sterling Walnut Napoli...
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
Fault code 116-324 what can i do to fix this problem
116-324 System Controller RAP
An exceptional Controller error shut down the processor.
Initial Actions
Power Off/On
Procedure
Pull out and insert or replace the DIMM (PL 11.2).
If the problem persists, replace the ESS PWB (PL 11.2).
116-325 ESS Fan RAP
The ESS fan failed.
Procedure
Replace the ESS fan (PL 11.2).
Apr 30, 2011 | Xerox WorkCentre 7132 PCL 6
Electric fan model ht38r...press buttons and lights light up but no fan and no movement.
Hi.
If the fan lights are turning on, but the fan is not spinning, check first that there is no mechanical problem or obstruction, check also starter switch then eventually replace the fan capacitor, that is most common cause for this fault.
See also: Ceiling Fan Capactors.
Jan 13, 2010 | Holmes Products Dryers
My x box power button lights red and doesn't turn
Yes this is the red ring of death you will need to stop the heat build up on the GPU and the CPU to do this you need to use a good guide or you will have to send it in.
Dec 26, 2009 | Microsoft Xbox 360 Console
KDF60XBR950 doesnt turn on....fan is on just flashes green
There is no less than two Cooling Fans on the right side. Either one of them could cause the problem. The one that turns slow or stops turning quickly is the one that is probably causing the problem.
I hope this helps,
Sky Assoc
Sep 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Monte Carlo 5AHR60OCD Arch Old Chicago Ceiling Fan Logo
127 people viewed this question
Top Monte Carlo Dryers Experts
Craig Butler
Craig Butler
Rani wadia
Rani wadia
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
