Question about Uniden Cordless Phone
Purchased GE 27911 EE 1 to go with my Base GE 27909 EE 1
I, and my son and daughter, have tried to register the two new handsets that I purchased to go with my base I purchased earlier and it has not been successful. It acts like it is not compatible.
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
How do I get the blue light and new voice mail cleared from this phone?
Posted on Apr 03, 2008
SOURCE: I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Posted on Apr 02, 2009
FIXYA Benny
  • 165 Answers
SOURCE: I have a GE cordless handset Model 27911 that I
trun off phone and remove battery
remove power from the base unit
and leave them unpluged for 5 mins or more
then turn both units on
and replce onto base unit . Good luck
Posted on May 04, 2009
SOURCE: Can't get handset to register
After each registration of a handset, you need to hold the page button on the base for 5+ seconds. If you then get an error tone, you'll likely have to return the phone due to a hardware problem. What did you do?
Posted on May 15, 2009
SOURCE: How to remove Uniden handset from base
The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
Posted on Jun 27, 2009
How can I register my GE 27911 handset?
I also had this problem and then I found a solution from another site.
Just open the handset and remove the battery for about 1 minute.
Reinstall the battery and go through the register procedure again - it will register almost immediately. just keep the handset near the base.
Jul 18, 2009 | Uniden Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
I have a GE cordless handset Model 27911 that I cannot get to register to the main base unit which is a GE Model 27909. I have tried followed the instructions and still the handsets says "Not register."...
May 04, 2009 | Uniden Cordless Phone
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
Dect 6.0
Hi :I have the same problem and the dealer couldn't help me .I replaced the battery but that wasn't the solution.Glad to see i'm not the only one with this problem
Mar 22, 2008 | Uniden Cordless Phone
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Please register
I charged my three brand new GE model 25922 for 24 hours, placed each handset in the main base to satisfy the "PLEASE REGISTER" message and the message remains. The only instruction in the manual as well as on the 800 448-0329 # is to place each handset in the base unit for 20 seconds.
Dec 03, 2007 | Uniden Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Uniden Cordless Phone Logo
69 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
