Question about Dell W2607C Television
Dell Model no. 2607C. 26 inch monitor. LED at power switch button comes on blue then flases amber three times and continues to repeat. Power board shows high heat at diode TVS901. appears to have open circuit at connection, copper trace is burn't. Diode shows open in one direction and some resistence in opposite direction. Caps all test good using DCR ESR CapAnalyzer.Tried repairing the trace using same diode, Amber flashes went from 5 to three. What is the value of the diode? and any other suggestions. Thanks, Dan
  • Bob  Adam
    Bob Adam Sep 10, 2011
    I'm in the exact same boat, did you ever get anywhere with yours, it was almost three years ago, but it would help me out. I've checked caps which are all good, I've got a nice burn mark but the traces all seem to be good all around that diode. When I turn mine on I get solid blue light, but you can't turn it off with the button, and nothing shows up on the screen. I found the value but the diode appears to work correctly too.
  • rene Oct 01, 2015
    Just saw the same thing around that diode. Any fix for it? Would it be better to put a new power board, just hope it wasn't some other board that fried it
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
You need the service manual for this. Try to find the service manual in the net. Or chamge the power supply board. Good luck.
Serge.
Posted on Oct 01, 2015
headstrong
  • 233 Answers
SOURCE: Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
SOURCE: no power
Dell has a recall on this item (at least for no power). I purchased mine in 2006 and there is apparently a 3 year window where you will get a new one replaced for free. Just call tech support give them your service tag, and ask to have it replaced under the recall.
Posted on May 19, 2008
  • 5 Answers
SOURCE: Model W2607C. Does not power up.
Check all of the fuses inside. If none are blown, unplug and hold power button for 20 seconds thus resetting all of the capacitors. Plug in and hold power button for 20 seconds thus powering the capacitors up safely. should work
Posted on Sep 04, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a w2607c that doesn't display when I turn
You need to troubleshooting it to narrow down to which board is bad, it can be the power supply board or the backlight inverter baords.
http://www.shopjimmy.com/catalogsearch/result/?q=Dell+W2607C
You need to do the voltage checking and visual inspection.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 13, 2010
lovejoy91
  • 691 Answers
SOURCE: Dell TV has flashing amber
Bad capacitors in Power supply, they maybe bulging out on top
Posted on May 01, 2011
I Have an XPS M1530 which won't switch on.
replace the motherboard. You can find the part cheaper than dell here at
www.partpeople.com they specialize in dell replacement parts.
Just type in XPS M1530 in the search box to see if they have the product,
Also if they dont
then contact Dell Spare Parts Division
1-800-456-3355
Apr 14, 2010 | Computers & Internet
I've a dell inspiron 1521 battery problem
The battery has an internal failure (Most likely a bad cell) While the battery works, the resolution for the LED indication is to replace the battery. Batteries are a consumable item and generally, batteries have a life of 300 to 500 recharge/discharge cycles before replacement is necessary.
Oct 17, 2009 | Dell Computers & Internet
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
AMBER LIGHT ON?
can you try this? unplug the pc, hold down the power switch until the amber light goes off, then (with the pc still unplugged) push the power button to see if the amber light comes back on, if it does, repeat the first step. do this until no light comes on when the power button is pushed. after you've done this. plug the pc back up, then hit the power button. what happens?
ive had this happen to a lot of my dell pc's here at work, but all i can figure out is that its a mobo problem, i also have tried swapping PSU's, but it didnt help.
Mar 16, 2009 | Gateway Computers & Internet
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
How to fix a dell monitor dimension 2400 power button broken
The last guest left us hanging with, "easy fix" so, I ventured ahead to see what I could see by opening up my lcd, which was a puzzle in itself. After UNPLUGGING the monitor and removing the stand and the 4 obvious screws in the back, turn the monitor onto its back and placing your palms against one side of the monitor, and using your FINGER TIPS, gently pull back the plastic lip away from the LCD screen. Move along the lip, doing this a little bit at a time. You'll hear and feel it snap loose. Repeat on the remaining three sides. It may take a few rotations to free all the sides, doing a little at a time, so as not to put undo stress on the plastic that is not yet loose. The bottom lip from behind which lies the offending "on/off" button will not move as freely as the other sides because of the ribbon cord that attaches the circuit panel to the main body. So STOP pulling when you feel it become taught and carefully turn the monitor onto its face to complete the face's removal. Undo the cloth tape that secures the ribbon cable to the monitor. This will give you the necessary slack you need to do your dirty work. BTW, we're not disconnecting the ribbon cable from its connections- that would be bad - just remove that haphazardly placed piece of tape used to keep the thing snug and save it for when you're ready to close it back up. OKAY! There a four tiny screws that affix the green circuit board. You'll need a thin, jewelers type phillips head or a one from a synthe-sized tool set to remove these. Now, if your issue is like mine, you'll see when you again carefully remove the circuit board, that the on/off button has cracked off of the piece that holds it. This is why the button remained stuck in one positon when it was depressed. Re-align it so that it is uniform to the other buttons and place a few small strips of cut electrical tape to hold it in place to the end where it broke off. Crazy glue or the like won't give the button the flexability it needs and will probably just crack again. What the tape (I layered 3 strips) will do, once the circuit board is scewed back, is allow the button to return to position after it's pushed. I just did this and so far, after a dozen on/offs it's still working. Good luck. Go have a beer.
Sep 05, 2007 | Dell Dimension 2400 PC Desktop
Televison & Video Logo
610 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
