I am needing to do an oil change for my car which has been sitting for about 6 months outside in the open weather. I would like to put something in there that is best for older diesel engines as well, I think I may need to put a fuel line conditioner as well as I think there is condensation in the fuel tank/lines. Can you tell me the optimal oil and conditioner to use? Thanks very much!
SOURCE: 1985 B reg T3 Transporter 1.6 Diesel LHD
Hello, i have recently purchase an 85 vanagon westfalia, with a 93 turbo diesel toyota engine, and it does not fit, so some modifications were made, such as the matress on top of the engine on the back had to be cut ,, its like a big square, its not that bad, i can still put a thin matress on top of that square and its just not as soft,,, but my real problem is that i still have the same 4 gear vw transmition, so i am now in the quest of a vw golf 5 gear transmition that would fit , my other option was a subaru transmition ,, but it was kind of expensive, if anyone reading this know of other options please let me know ,, also i was told that i have to change the radiator & fan for a bigger one and also see a way to install some sort of fan right next to the engine on the back,, since diesel engines run hotter,, i am not really a gear head ,, dont know much about this things.... any comments or recommendations?
miguel
SOURCE: Changing the Oil Filter on 2005 Jetta 2.5L Gas Engine
Is this the valve that you are speaking of?
http://www.toolsource.com/filter-housing-drain-audi-p-99593.html
Let me know,
Brian
SOURCE: Engine oil indicator blinking
Sounds like it could be a sludge issue which can be caused from using the incorrect oil. It is a very specific synthetic type of oil that VW suggests and when you don't use it the engine can actually 'gunk' up and cause turbo failure. (This problem happened when a non-vw dealer sold me my car with the wrong type of synthetic in it and my turbo seized)
Google: "1.8t specific oil"
SOURCE: severe engine clunking after oil change
Appearently Mr Lube is either going to end up fixing your car. I dont know what could have happend other than maybe they put the wrong type of oil back in it. I would definately get ahold of some of the higher ups at Mr Lube and "Ensure" they put your car back the way it was when it arrived there. There is no purely coincidence about it. They were the last ones to touch it. They will be the first ones to fix it. Make sure you are very firm with them, and keep track of names/dates/events as this important if you need to consult an attorney because of their negligence. Hope this gives you some direction, Thanks for using FixYa!
JC
SOURCE: Eratic idling and misfiring under pressure
confirm that the fuel pump delivers the proper pressure to the injectors
