Question about Tricity Bendix AW1000W Front Load Washer
TRICITY BENDIX AW1000W INLET HOSE LEAKING
Had my machine fitted and its been leaking a very small amount gradually. The inlet hose that attaches to the machine is wet round the outside. I took it off and there is no washer in it. Do you know if there should be one to seal it because it doesnt seem to fit properly.
  • gbaileyis Jan 07, 2009
    Thank you so much for your help, I've just fitted a washer and will test in the morning.
  • Tricity Bendix Master
  • 3,463 Answers
There should be a rubber washer fitted in the end of the hose.
If after fitting one it still leaks, then you will have to replace the hose, as it means that the metal clamp on the end of the hose is loose, and is not repairable.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Water comeing out from the bottom of washer
It sounds like you might have a leak in either the water inlet or drain line. If water is hitting the motor it is probably causing a short. Unless you are handy call a professional other wise some investigative surgery is called for.
Nov 10, 2012 | Tricity Bendix AW1000W Front Load Washer
Why won't my tricity bendix aw1000w drain?
Check the filter and pump for coins, hair grips, screws etc and check the drain hose isn't blocked or kinked
May 09, 2012 | Washing Machines
Iv got a Bendix BIW103W, water runs to machine from mains, no blockages, but only trickles into dispencer, doesnt take powder or fab softner into drum, otherwise works ok,
i would check the water inlet on machine............take the hose off there should be a small filter inside. might be blocked..................
cheers
Mar 31, 2011 | Tricity Bendix AW1000W Front Load Washer
Washer has hot and cold inlet but I only a have cold water suply
What you need is a fitting called a (Y) piece.
This is usually available from any good hardware store such as B&Q, and the like.
It allows you connect the hot and cold hoses to the 2 legs of the fitting, and then connect your 2 hoses to the washer.
The straight leg of the fitting then connects to your cild water inlet supply.
This will give you a feed to both inlet valves on washer.
Dec 12, 2010 | Tricity Bendix AW1000W Front Load Washer
I have mislaid my manual. i am trying to clean the filter of my tricity bendix 1000rmp washing machine. I opened the small door at the bottom right of the machine and unscrewed the cap inside . now the...
Make sure the filter and the housing are clean and that there is no grit or similar on the seal, if it still leaks, then you may have to fit a new filter and or seal.
Nov 05, 2010 | Tricity Bendix AW1000W Front Load Washer
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
Feb 23, 2009 | Haier HWD1000
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Mar 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
87 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
