Dell W1700 17 in. HDTV-Ready LCD Television
Problem for Dell W1700 17 in. HDTV-Ready LCD Television
Dell W1700 When I turn it on, the picture comes on for a moment
By jammac020 on Jan 07, 2009
looked and I need a backlight inverter. Which one do I need?
Best Solution
posted on Jan 07, 2009
Very Helpful)
jryduke
Rank: Master
Rating: 100%, 3 votes
If you Google W1700 backlight you can find vendors that supply replacement backlight inverters. They usually run around $90. If you are handy electronically, you can probably repair yours for about $5. The normal fault on the W1700 backlight inverter is either one or two blown fuses and one or two faulty electrolytic capacitors. These are the tublar looking devices about an inch long and about diameter of a ballpoint pen. When these fail, the top of the unit will bulge out where the case has ruptured to allow gasses to escape. You can get replacement capacitors at Radio Shack, There is a translated narative with pictures describing the removal and replacement of the inverter assembly on line at: http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Fangelitodiaz.blogspot.com%2F2007%2F10%2Fmonitor-dell-w1700.html&lp=es_en It does not describe the actual replacement of the capacitors, just remember to orient the replacement capacitors properly. One side of the capacitor will be marked with a stripe and - - - signs. One hole on the board will be marked +. Be certain that you DO NOT mount the capacitor with the - marking in the + marked hole. Also don't forget to check and replace the fuses if necessary.
Was this helpful?
Yes
No
Popular Solutions for Dell W1700 17 in. HDTV-Ready
Questions and Unsolved Problems for Dell W1700 17 in. HDTV-Ready
Do you recommend Dell W1700 17 in. HDTV-Ready LCD Television?
Answer
Answer
i was sitting watching the TV then the picture went out.
Answer
turns on can hear audio green power button light comes on but no picture
Answer
i have a dell w1700 and when i click the power button it flashes the yellow/orange light then it... (More)
Answer
My monitor is all black, no picture. I checked all the cables and power inputs. I tried it on... (More)
Answer
hi evey time i turn my dell w1700 off it keep coming back on .i check the adapter the volt is only... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
