Wireless network everytime I close the notebook or it's in sleep mode and open it back I lose my wireless connection and can't connect unless I reboot. the operating system is windows xp home edition. how can I fix this so I don't have to reboot all the time?
  • rafart1204 Jan 07, 2009
    even when I close my wireless connection before puuting pc to sleep, still when I open it won't connect unless I reboot.
  • Anonymous Jan 07, 2009
    thanks for your help, it didn't work, for some reason the connection is not there, it;s not finding the wireless network unless I reboot.
    President:
  • 2,559 Answers
Step1.Go to Start Settings Control Panel and double click on the System icon.Click on the Hardware Tab and select Device Manager.
Step 2.From the Device Manager window, Scroll down click on Network adapters, select and right click on the wireless adapter and select properties.
Step 3.From the adapter properties window select the Advanced Tab and under the “Property:” window scroll and select “Power Management.” From the Power Management tab uncheck the box that indicates, “Allow the computer to turn off this device to save power.” Then Click Ok
(Note: It is important to note these changes will not take effect until the wireless radio is reset by turning it off and then on again.)
Posted on Jan 07, 2009
    Problem Solver:
  • 10 Answers
When a laptop shutdown it closes all processes and drivers including the wireless driver in your case and then closes the power input which makes the computer shutdown.
And when a laptop goes to sleep is closes and saves all processes and then temporarily closes the power input to some parts of the computer.So that it can boot up again after you press the power button.
So i think its normal that your wireless connection closes when you go to sleep or shutdown your laptop.
But the part where your wireless connection can't connect.
You should update your wireless card driver and make sure that you close your wireless connection before putting the computer to sleep, mainly i don't think that this problem exist in all Acer Laptops i also have an Acer 7520 and have never experienced this problem myself but have heard of it.You shoud definiatly try closing down your wireless connection before putting the laptop to sleep
Please Rate, Thanks
Wireless disconnect in sleep mode?
I think that is normal to conserve energy. There are times when it will take the network connections down to conserve energy.
If it is a problem you can always increase the time on the sleep mode or set it to NEVER.
May 13, 2012 | Dell Computers & Internet
I find 2 strong open signals but after saving them, I cannot connect to Internet in wireless mode to those open network addresses (the TL -WA5210G is connected directly to my notebook, DHCP auto mode is...
Incase Open networks are configured for MAC authentication(MAC binding) then you might not be able to connect to those networks. Even though Network is Open (Unsecured), if ACL (Access Control List) is enabled on the network then only those computers can connect whose MAC address is configured for that Network, its another Security feature on Routers.
Try connecting to some network which your are sure are Open (Unsecured)
Jul 06, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
Net book will not connect to internet through WiFi. With cable is ok
Here are some suggestions that may resolve your problem....
1. if another computer is connecting OK through WiFi, then the problem is likely with the N150
2. if nothing else is connected through WiFi, then you need to check both N150 and router
3. on N150 without cable, click start and click Control Panel then double click Network Connections
4. Network Connections should show Wireless Network Connection and Local Area Connection
5. if Wireless Network is missing, click back and double-click Wireless Network Setup Wizard
6. if wizard done but Wireless Network Connection is Not connected in Network Connections window
7. in Network Tasks in left sidebar of Network Connections, click View available wireless networks
8. in Wireless Network Connection window, click on Refresh network list in Network Tasks sidebar
9. if No wireless networks were found.... then Make sure the wireless switch on N150 is on
10. with the N150 wireless adapter now enabled, click on Refresh network list
11. if SSID for your router's wireless is listed but not high-lighted, click on it to select the SSID
12. click the connect button, if security-enabled wireless network, a pop-up appears for key input
13. click the connect button after entering and confirming key inputs
14. if after step 10 the SSID for your router is NOT listed, you will need to log into the router
15. connect the N150 to the router using the ethernet cable then open Internet Explorer
16. in IE's address field, type the router's IP address - it is in the form of 192.168.x.x
17. if it is not known, open Network Connections window (step 3) and right-click Local Area Connection
18. in the pop-up, click on status
19. in the Local Area Connection Status window, click on the Support tab
20. the Default Gateway has the router's IP address
21. after entry of IP address, IE presents a router login window for userid and password entry
22. unless changed, the router userid and password defaults are given in the router's manual
23. on the first router screen (usually Setup), click on the Wireless tab
24. if Wireless Network Mode is Disabled, click on v for pull-down then click on appropriate mode
25. if SSID is blank, enter a Wireless Network Name then click Wireless SSID Broadcast enable
26. click Save Settings then click on Wireless Security tab in the Wireless window to set WEP/WPA
27. see your router's manual for details on how to setup WEP or WPA mode and its key
28. if you don't want wireless security (OPEN), then set Security Mode to Disabled (default)
29. if any changes, click on Save Settings then click on x at top right corner of IE to close it
30. disconnect the ethernet cable and right-click the Toolbar's Wireless Network Connection icon
31. if the icon (a single screen with ))) beside it) has a little red x, then on the pop-up...
32. click View Available Wireless Networks then in Network Tasks sidebar click Refresh Network List
33. continue with connecting to the wireless network at step 11....
Feb 21, 2011 | Samsung N150 (36725723009) Netbook
How do i connect my dsixl to the internet
This is just a general guide ...
1) locate your cable modem connection on your notebook and open up its properties
2) in the advanced tab you should see the Internet Connection Sharing - click on Allow and choose Wireless Network Connection
3) Go back to Wireless Network COnnection, open up its properties
4) In the Advance tab, choose Computer-to-Computer (ad hoc)
5) UN-check the Automatically Connect to non-preferred Networks
Try that first with your built in Wireless Connection of the the notebook. For the USB stick, you should not have to change it to AP mode.
Jan 17, 2011 | Computers & Internet
Wireless network card in advent 5421 keeps losing
Check the propeties on the device and set to max performance and NOT to sleep mode at all. If still trouble buy a good Intel card on
www.ebay.com
Oct 10, 2009 | Computers & Internet
Losing connection to wireless router everytime rebooting
It seems that you have windows XP on this computer. Follow the steps below;
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 14, 2009 | Zyxel (91-004-361002) Wireless Router
Trouble with wireless network
Next time you connect to a network, check off the box that asks you if you always want to connect this network (or it says something like that). Let me know if this helps.
Jan 07, 2009 | Acer Computers & Internet
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
I have the same network card.
Never had this problem with Vista (32 bit) but recently switched to Win7 (64 bit) and had the same problem as you.
I solved by going under Control Panel->hardware->network card properties->power save and unchecking "Allow pc to switch off the device to save power"
Jul 13, 2008 | Intel Ethernet 10/100 Network Adapter
Losing ip address after skeep mode windows vista
I have a dlink product and the first thing I noticed about it was it was extremely unpredictable until I finally got it to a location where there was plenty of free moving air, and it's quiescent operating temperature could come down about ten or so degrees F. But it was not a problem that timed out with anything the PC was doing. An easy way to find out may be next time it happens, find a way to cool the innerds, (I sucked cool air through it and it would just start working again) If you blow, it may get moisture and warmer air in it. Who knows. What do you have to lose... unless a neighbor sees this activity thru a window!!!
Jan 25, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
276 people viewed this question
David Payne
David Payne
