Question about Samsung SyncMaster 931B 19" LCD Monitor
Samsung Syncmaster 931B monitors flickers for 20 minutes
I have a laptop with a samsung syncmaster 931B as the second monitor. When I activate the monitor, it flickers for around 20 minutes before it settles down. I have the resolution set at 1280x1024 32-bit color 72hertz refresh rate.
I've had this monitor for more than one year, without any problems. I've recently updated the nVidia Ge Force 7300 video drivers on my Windows XP Pro SP2 system.
Any suggestions?
Regards,
rcSingleton
  • 1 more comment
  • Randy Singleton
    Randy Singleton Jan 08, 2009
    Thanks for the suggestion, but the refresh rate is not the answer.
    Actually, the problem is not the monitor. I can connect this monitor to a second laptop and it works fine, with no flicker.
    I have PC-Doctor 5 installed and the video test for the nVidia GeForce 7300 and the external monitor itself ran with no problems.
    This is a strange one. Again, after 10 - 15 minutes the monitor flickering ends and it works fine.
    Any other suggestions?
  • Randy Singleton
    Thanks for the answer, but this problem was occurring before the updated drivers.
  • Randy Singleton
    Randy Singleton Jan 09, 2009
    Thanks for all the responses.
    Its not the monitor. When I connect the monitor to a different laptop it works fine, without any flicker.
    But you could be on the right track, concerning a temperature dependent issue.
    I think what is happening is there might be a problem with VGA connector card on the laptop.
    Its not the GPU, because it passes all video tests and there is no problem with the laptop display.
    In order to test my theory, I'm going to bring up the laptop tomorrow and leave it running for around 30 mins.
    Then I'll connect the external monitor. If it works, without flicker, then its a temperature dependent problem with the VGA connector card. I'll then just replace card.
    Will let you know
    Sergeant:
    Champion:
  • 435 Answers
Hi, sounds like a bad capacitor. Since how long does this happen.?
Open the circuit for any dirts/ dusts on it. Also look for any hot capacitors.
Posted on Jan 09, 2009
    Sergeant:
  • 378 Answers
Try connecting another monitor to the machine and check out if the same problem exists then its definately something got loose in the machine.just shut off the machine and refit all the cards properly and check out it may solve this problem of flickering.
Posted on Jan 08, 2009
  • 505 Answers
If letting it run for 20 minutes seems to resolve the issue, it cannot be any setting or software.. It would have to be some sort of hardware failure.. temperature dependent. You may bypass the problem by changing resolution/refresh but there still lies the underlying hardware issue. It could be as simple as a solder connection that is loose when cold. Try hooking to another computer to confirm that problem is on the other as well and this is your course of action. If so, I would open the monitor and check the power supply for leaky capacitors, the tops will be bulged not flat, or there will be some liquid coming out of the bottom.. check the 1000uf caps escpecially. You can lightly tap around with an insulated screwdriver to see if there is a loose connection somwhere, however this may be harder to repair and find. Check the video cable as it gets most stress from the outside connections.. I can assist further depending on what you find.
    President:
  • Samsung Master
  • 1,314 Answers
Try restoring your video card's original drivers.
    Scholar:
  • 111 Answers
If this monitor is capable of increasing the refresh rate do so as flickering can generally be associated with a low refresh rate
  • Curtis Tuendemann Jan 08, 2009
    Try a driver rollback - To do so;
    Right Click my computer
    Properties
    Hardware Tab
    Device Manager
    Click the Display Adapters Drop Down menu
    Right Click your Video Card
    Properties
    Driver
    Roll Back Driver
    Hope this helps
  • Samsung Master
  • 19,396 Answers
The problem is with the video card hertz rate.
  • Ginko
    Ginko Jan 08, 2009
    The problem is with the video card hertz rate.I think this monitor has a refresh rate of 60 hertz.
    See if you can lower down refresh rate to 60 Hertz on your video card.
    If that does not work, wait few seconds and restore original screen settings.
Samsung syncmaster 933 moniter screen was blinking
THER IS NO SIGNAL FROM THE PC DUE TO WHICH UR MONITOR IS NOT DISPLAYING THE SCREEN KINDLY CHECK THE CORD OF THE MONITOR WHICH IS CONNECTED TO THE PC OR MAY BE UR PC IS NOT BOOTING UP DUE TO WHICH U PC IS NOT GETTING DISPLAY
Nov 16, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Screen blinks on /off - can syncmaster 931b be repaired?
This model was released in 2001, you need to open it up and look for bad caps with bulging top first, the problem can also be in the backlight inverter circuits. Post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 27, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I am using Ubuntu 9.10 in a dual-boot config with XP. I have a Samsung Synchmaster 931B monitor in analog mode. Works fine and drivers installed under XP, but will not support extended effects under...
it's your graphics card not the monitor that often has proprietary drivers to drive compiz and other effects.
If this is not a laptop, then it is easy to interchange.
Nvidia is one such vendor that supplies special drivers for Ubuntu
Jan 29, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Syncmaster 920 nw lcd monitor dispaly problem
sounds like your having pixel issues I would advice calling up samsung and checking there pixel policy if it is out of range they will need to replace it
Dec 16, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung SyncMaster 931B 19" LCD Monitor Logo
570 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
