Question about Kenwood KDC-MP828 CD Player
Audio Output problems
I recently baught a '95 chrysler lhs and installed this deck from my old car. This deck has been great for me in the past. When I play the radio in this new car the audio is perfect, love it. My subwoofer and my stock speakers work. But, heres the problem. When I try to play a cd or try to play audio files from my iPod(kenwood ipod interface) I only get sound from my subwoofers. My stock speakers make no noise at all, and i can't figure out why. :\ Any help on this would be greatly apprieciated.
I had the same problem with my lhs I had to hook the red wire to the blue factory remote wire in order for the factory amp to kick on while my cd payer was on. My kenwood head unit didn't have another wire for an alternt the red is a power and so far has not drained the battery
Posted on Jun 17, 2012
  • 156 Answers
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
Posted on Jun 04, 2007
My 2001 Chrysler LHS started smoking from under the hood when I turned off car and poured out a brown fluid from underneath car...
Its probably old worn out antifreeze/coolant.. HOPEFULLY not oil...you need to contact a QUALIFIED professional...Hopefully new hoses, thermostat, (maybe water pump)and a good flushing will fix the problem..pray its not oil...you will need to have the car towed to the repair shop.. ask around..(friends, neighbors,(google search with GREAT reviews) and do not chose one at random...
Good luck..
Jul 25, 2017 | 2000 Chrysler LHS
95 chrysler lhs transmission problems again
Since this car is over twenty years old and on the market only worth $500.00 in running condition it is not worth putting more money in to it. I feel you have transmission troubles. Because of the low mileage it has been sitting a lot. That alone will cause things to not work.
Sep 21, 2017 | 1995 Chrysler LHS
My 95 lhs wont start in hot weather and stales out cold
Also replace the camshaft sensor and fuel filter.
May 09, 2009 | 1995 Chrysler LHS
95 chrysler starts, runs for 5 seconds and shut off. Gauges don't work
I suggest that you go to ALLDATA.COM and take out a subscription for ALLDATADIY, this access can give you unlimited knowledge about your vehicle. I have a repair manuel also between the two reference media I have solved most of the problems you are facing. Not to mention the problems you will be facing with a vehicle this old.
Apr 22, 2009 | 1995 Chrysler LHS
Car
if you fallow the possitive cable down you will see the starter
Feb 17, 2009 | 1995 Chrysler LHS
Starter
the starter is ALWAYS found toward the back of the block connected to the flywheel ( closer to the windsheild) . you will most likely have to get to it from under your car
Battery is Being Drained in 1996 Chrysler LHS
I’m having this same problem on my 99 LHS, I’ve been told that it’s caused the body control module. Maybe a bad ground?
Dec 01, 2008 | 1999 Chrysler Concorde
I recently baught the rockford fosgate P2's and i got the KAC9103 ampliyfer. and i had best buy install em both and they ran the wires too. the problem is when i crank the volume on the deck to...
It's possible that the installer cheated on wiring gauge, using wire too light for the 12v side causing the voltage to be dropped to a level the Fosgate won't tolerate and causing it to shut down.
If you have a multimeter, monitor the supply voltage at the amplifier while a friend turns the volume up. If you see a significant decrease in the 12 volts, the wire feeding the amp is too light.
Sep 23, 2008 | Kenwood KAC-9103D Car Audio Amplifier
Chrysler
1994 chryler LHS exhaust inside my car when im driving
help feel sick
Jun 01, 2008 | 1995 Chrysler LHS
Kenwood KDC-MP828 CD Player Logo
269 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
