Question about Dell (3410160) Plug-In Module DVD Drive
Dell laptop install new dvd drive module and software
I have a dell inspiron 600m with cd player. I bought a new dell dvd drive module (c3284-a00) and software (dell dvd application cyberlink power dvd dx7.0 and roxio creator 9.0de). I'd like to install all this myself. I think module is plug in and easy to install. Am I right? Do I install software first with old cd player and then plug in dvd module or other way around. Which software disk first? I'm trying to save money and do this myself. Thanks for the help. Mike Z.
  • 827 Answers
Install the DVD drive first, mate.
Then when you install your Cyberlink and Roxio software, they will autodetect the drive. If you did it the other way round, it would probably still work, but the correct driver might not be installed and you would have to do find and do that manually.. and you would have to into the tools/options and select the new drive from the list.
So the drive first, then the software.
Hope this helps
Chris (ziraffa)
Posted on Jan 07, 2009
  • chris grams
    chris grams Jan 07, 2009
    Also the 2 disks are separate programs and not dependent on each other, so install both,in whatever order, but AFTER you install the drive.
  • 916 Answers
When you install the hardware your computer should recognize it and automatically install the drivers but if you would like to be on the safe side run the software will the old drive first and then install the new one.
  • 679 Answers
Just plug your new drive in.
and see its work
  • Dell Master
  • 19,396 Answers
If you are installing an internal drive you do not need any software, the module is completely plug and play, just insrt the drive in the slot and screw it back after removing original one.
  • Ginko
    Ginko Jan 07, 2009
    What you have to do is replacing the Cd player drive with the DVD, by unlocking and unscrewing the safety screws on the bottom side of the laptop.
    Ensure that battery is out and poer charger not connected when you do this.
    Once you pull out the Drive jiust push in new DVD drive, screw back and restart the unit.
    The module will be detected automatically.
    The software is a separate matter, you can install the software on Windows at any time, but it is better to install the software after you fit in the new DVD drive, and after you restart the computer .
    I will be grateful if you can give me feedback on this.
    Many thanks.
  • Dell Master
  • 13,433 Answers
No the software is not important as the drive has all what it needs with windows.
basicly a service manual for your laptop is what you need to take it apart easyly.
replace the drive
Load any extra software you require.
Dvd drive wont work on laptop
when was the last time was it working???
have you tried doing a system restore.
check for the device manager if the drive is detected under CD/DVD option.
if not try to instal the basic chipset drivers for your laptop and see if that works.
Nov 22, 2014 | Dell Inspiron 600M Notebook
Dell inspiron 600m cd/dvd code 19
ac7h,
Tell me what driver you downloaded, AND how you installed it?
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-600m
Removable Storage
The method is to;
1) Click on the blue Download File to the right.
2) On the next page under the bold subheading - Choose Download Method, make sure there is a green dot in the small circle, to the left of -> Single-file download
If not; click in the small empty circle to the left of Single-file download
Now click on Continue in the blue oval.
A small window will come up.
Make SURE there is a Green dot in the small circle, to the left of -
Save File.
If not; left-click in the small empty circle to the left of - Save File
Go below in the window, and click on OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name.
To the far left in the next window click right on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
If you are not asked to restart your computer do so.
(Start > Turn Off Computer > Restart)
When Windows fully loads again, you should get a pop-up out of the system tray, "Found new hardware device"
And perhaps another one, "Found xxxxx CD/DVD drive"
No?
Wait a few minutes, let Windows run.
Turn the computer off normally.
WAIT 1 minute, turn the computer back on.
Still no?
I suggest then that the optical drive is bad. (CD/DVD drive)
One screw removed from the bottom, (ALL power removed), then slide the CD/DVD drive out to replace,
http://support.dell.com/support/edocs/systems/ins600m/en/sm/index.htm
http://support.dell.com/support/edocs/systems/ins600m/en/sm/upgrades.htm#1019383
http://www.discountelectronics.com/category?product_model=134&category=1&product_type[11]=11
Optical drives are a mechanical device, and rated in hours of usage.
Eventually they wear out, and go to the great optical drive graveyard in the sky. (What?)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 23, 2013 | Dell Inspiron™ 600M PC Notebook
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
I need a driver for 8 x cd-rw/dvd 8f947-a00
Feb 05, 2011 | Dell Latitude / Inspiron CD-CDRW/DVD Combo...
My dell dvd drive module (c3284-a00) has been installed for awhile, but now it doesn't recognize that there is a dvd in there........any suggestions?
try to reseat the drive. if you see the light on the drive its okay, then we may need to reisntall the operating system,. there are no drivers for the cd drive which can be installed. but if there is no light try to reseat the drive.
Oct 13, 2009 | Dell (3410160) Plug-In Module DVD Drive
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
I have a Dell Inspiron 600m laptop that won't play any DVDs. A message pops up telling me to make sure the DVD software is installed in my computer. The laptop came with the DVD player installed and a...
1. Have you checked the programmes on the unit?
2. What software are you running i.e Windows Os or Mac?
3. Is there a Dell Config file on computer ?
Let me know and i will try to help from there
Fredknirk
Feb 20, 2009 | Dell DVD-rom DVD Drive
My hard drive took a **** and my dvd burner will not pop out
Hi a_stoeger, it is possible for you to get what you need. Or even better. Below is a list of links for your viewing. The best site is the first link.
Hard disk drives for the Inspiron 600M laptop. (Great site).
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=dll&pos=0&type=itemid&itemid=dll9
CMS Products Easy-Plug Easy-Go Hard Drive - 60GB - 4200rpm – Ultra
This hard drive is designed for Dell Inspiron 500, 600m Series.
http://www.google.com/products?q=60GB+Ultra+ATA+Hard+Drive+for+Inspiron+600M+notebook&btnG=Search+Products&hl=en&show=dd
Brand New CD-RW/DVD Combo DRIVE for Dell INSPIRON: 300M,500M,510M,600M.
http://www.acer-laptop-battery.com/cdrwdvd-combo-drive-dell-precision-m20m60m70-p-466.html?zenid=12m5dirv47ffvjf6jc5pc85lp0
New combo drive. Fits the 600M
http://www.upgrademaster.com/dvdrw-cdrw-drives-c628/dell-dvdrw-cdrw-combo-drive-p26078.html
Brand New CD-RW/DVD Combo DRIVE for 600M 500M With One year Warranty
http://www.power2battery.com/dell-inspiron-600m-500m-cdrwdvd-combo-drive-p-697.html
If there is any life left in your notebook drive connecting it to another IDE drive could allow you to transfer the data to the PC.
This next link is for connecting your laptop drive to a PC drive.
http://www.paddlersite.com/2lato3deideh.html
Cost effective!
Good luck a_stoeger!
Mike
Jan 05, 2009 | Dell (04U621) for Latitude D600, Inspiron...
Dell (3410160) Plug-In Module DVD Drive Logo
74 people viewed this question
Alun Cox
