Amana-80sse furnace turns it's self off after starting.
We had water in the basement. i turn furnace on andblower starts, then the filament gets warm, but then it turns it's self off.
Thats going to be a gas valve issue. either their is no gas to the valve or its not letting it go through. and you also need to make sure the exhaust fan is running too.
Posted on Jan 08, 2009
Amana 80sse furnace fire up work for about 10 min. It goes in lockout and inducer motor stay on
Robert, that is a typical indication of the furnace cycling on its high temperature switch. Look for a dirty filter, return air blockage or any other thing that would cause air flow restriction across the heat exchanger. If nothing else is evident, possibly attempt changing the heating speed to medium low or medium high for heat to improve air flow. But if it worked with no changes prior to this problem, it has to be lack of air flow that is causing the issue.
Dec 15, 2015 | Amana GMH81405DN 140,000 BTU 80% Gas...
Wires were removed to test the motor. I need a picture so I can double check that the wires were reconnected correctly. model no. GUico70ca30 amana 80sse furnace
Main blower? The white wire goes to neutral. Two brown wires go to the capacitor. All other wires are your speeds. Red is low, normally not connected. Black is high, that should plug into "cool" on the board. Your other one or two colors, EITHER of those can go to the "heat" terminal. Tape off your remaining wire, if you have one.
Nov 03, 2013 | Heating & Cooling
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
Amana Model LWABOAW Manufacturer # PLWABOAW Age: Approximately 12 years. Ran fine up to now. This morning the machine would not run using Cold/Cold setting. If the Warm/Warm, Warm/Cold or Hot/Cold...
Hi
I believe the issue is with the water inlet valve assembly going bad and should be replaced, this unit has two valve one for cold and another for hot. You can test the valve first if that is fine then check the pressure switch which is part#4 in this diagram. Hope this helps...please post back for further assistance.
Daniel
Jan 19, 2011 | Amana Washing Machines
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Dec 26, 2009 | Honeywell Electronic Programmable...
The fan motor went out and the furnace is not even 5 years old.
I have an Amana High Efficiency furnace that I purchased 5 years ago this past October (2009). My furnace started making a horrible noise last night and then stopped working. The repair person, told me my draft inducer motor needed replaced, and showed me where the plastic fan blade inside of the inducer was "chewed up." Of course my first question is, "How can a 5 year old furnace need such a costly repair already?" The only answer I received is that it will cost me close to $500.00 to have the situation remedied (service call, parts, labor). I started looking around on the internet today, and discovered that high efficiency furnace inducer motors are usually encased in plastic and the motor fan blades are made of plastic rather than metal like the lower efficiency models. Turns out that these plastic blades over time can't withstand the high heat generated and in time (they estimate 3-4 years) break. The damage to the blades causes an imbalance in the way they spin, which in turn, generates the resulting problem of a damaged draft inducer motor. Appears this is a design flaw. Yeah! I'll say. I spent $3100.00 for a brand new furnace and 5 years later I'm paying another $500.00 and apparently can look forward to doing the same in 3-5 more years! Maybe this answers in part your question?
Dec 07, 2009 | Goodman Furnace Draft Inducer Blower ...
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
Burners come on and go out amana 80sse
Ths is an easy problen to solve. Looking close to the burners is a pilot sensor. It looks like a thin metal pin about 1" 1/2 long. Clean this with sandpaper. This will allow you furnace to stay lit.
Hope this helps,
RepairUSA
Nov 25, 2007 | Heating & Cooling
Amana 80SSE Furnace
Not much info to go on, but lets look at a few possibilities. Your thermostat could be turned to the ?Fan On? setting, make sure you put it in the ?Auto? mode. Or it could be bad, or there could be a short in the wiring. Open up the access panel on your furnace. Lets eliminate the thermostat from the equation by disconnecting the red, white and if you have a yellow wire at the furnace. Mark down which wire went where. The furnace will have a door safety switch that will have to be taped temporarily closed to test the furnace. With a short piece of wire (2-3" long), strip off 1/2 inch of the insulation on both ends. Secure one end on the R terminal where you removed the red wire from your thermostat. Take the other end and touch the G terminal on the same electrical board. Your fan will start. Don't worry about an electrical shock, the voltage is only 24 volts. Now with one end still attached to the R terminal, touch the W terminal where the white wire was attached. The furnace will now try to fire up. Hold it there until you see that it did start. If you did this and had success, I would say it was your thermostat or the wire going to it. Last resort would be a bad control board. If you want, you can do test your thermostat wiring by removing the thermostat from it's mounting plate. Put all wires back where they were on the furnace. Make sure the access door is back in place and secure. Take that same jumper and jump across the red and white wires on the mounting plate. Again the furnace should start up. Have a helper jiggle the thermostat wires where accessible when the furnace is running and see if it remains on or shuts off. If everything checks out, replace the thermostat. Good Luck!
Oct 08, 2007 | Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
