Question about Intel (5184-0062) Processor Board
Will not boot
I have unpluged all extra boards and drives, etc. I also have verifyed correct voltages coming out of the power supply. The power supply fan and cpu fan run but that's about all it does. No boot screen, no bios screen etc. When I opened the case the cpu fan was unplugged!
  • artiacousmc May 11, 2010
    here is a kicker question, what there thermal grease/gel/paste between the processor and heatsink?
    Problem Solver:
  • 17 Answers
Plug the cpu fan tightly and try again it might be overheating.
Posted on Mar 07, 2009
Dell xps 710 motherboard replaced with 700 motherboard but it does not boot
This could be any number of problems. First start with hardware. Is everything seated and connected correctly? Are the hard drives installed correctly. Are the power on pins on the board set correctly or pinned at all? Is the ram the correct ram?
Check the hard drives, are they functional, do they boot with other computers?
Use a volt meter and check that the power supply is producing the correct voltages on all the connectors and rails.
If that all checks out, it might be a bios error. Check your boot load order and if the motherboard is detecting the hard drives, check that the correct bios settings for OS management are in place as this is a server. Is the RAM power settings (voltage) and speed correctly selected? Will the computer boot from optical drive using a live CD? Will it boot from a USB live OS (like Ubuntu)?
Since it's not booting, you may not have compatible hardware or damaged hardware. The OS that's installed on the hard drives may not be able to load on the new (older model) motherboard due to driver incompatibility.
Oct 13, 2013 | Intel Server Board SE7501BR2 Motherboard
Tip
How to replace a computer's power supply
The power supply is one of the most common components to fail inside a desktop computer. If you don't mind turning a screwdriver, you can replace a bad power supply yourself and save on repair costs.
Before purchasing a replacement power supply:
- Make sure to get a power supply that is rated for at least the same wattage as your current power supply.
- Verify that the new power supply has all of the necessary connectors that your current one has. You can either check this visually by looking at the connectors that you have, or by making sure your computer is listed as one of the models that the new power supply is compatible with.
- Make sure the new power supply will fit inside your computer's case. (If the new power supply is compatible with your computer, that won't be a concern.)
To install the new power supply:
- Turn your computer off and unplug it from its power source.
- Unplug all of the cables leading from your computer, including the power cable.
- Open the computer's case. (If you're not sure how to do this, you can probably look it up online. Most computers either have screws in the back that come out, a side panel that slides off, or they open up like a clamshell.)
- Disconnect all of the cables leading from your power supply. Note what component each connector plugs into. You should have connectors for your fan(s), hard drive(s), optical and/or floppy drive(s), motherboard (may be one or two connectors), and the front power switch.
- Unscrew the power supply from the system case and remove it.
- Set the new power supply in the case facing the same way as the old power supply and screw it in.
- Attach all of the connectors. (You may have more connectors than components, but make sure each component that was connected before is connected again now.)
- Close the system case and reattach any screws.
- Plug the power cable into the power supply and then into the wall outlet.
- Reattach all other cables.
- Make sure the power switch on the back of the power supply is on.
- Make sure the voltage switch on the back of the power supply is set to the correct voltage (115 volts in the United States).
- Turn on the computer and verify that it boots up correctly.
on Jan 29, 2011 | Computers & Internet
Vizio VT470M no picture, no sound, no backlight. Power supply board looks good all voltages appear correct (24V, 5V, and 3.7V) and no "bulged" capacitors . When I unplug unit for two hours, the...
Im having similar problem and with my limited knowledge of lcd tvs and the voltages ALL being good except the pwr on or sw on voltage from the main board to the power supply which tells it to switch everything on Im guessing that something is going wrong on the main board. In the condition where it freezes it (the power on V) which switches everything on i get varied voltages such as 2.5 or 3 or (the normal 5v) and then when nothing powers up (blank screen) i read 0v on pwr on voltage but all my other voltages are corect (24v to inverter, 12 v to main board, 5v, etc.) Im guessing from researching this is that there is in improper voltage somewhere in the main board circuit. I have been unable to find it so i may order another board and post back.
Jun 19, 2012 | Vizio VT470M 47 in. TV
I have an emachines t3958 w/ intel d845epi/d845gvsr, it will not turn on. i have replaced the power supply, and i believe everything is plugged in correctly. help!
Do any fans or lights come on?
Here's things I'd check:
-Replace Power supply (You already did this)
-Try a different AC outlet, remove any surge protector
-Remove the Power Button Cable from the MB and short those pins
with a screw driver just for a second.. (to eliminate a bad power button)
-Verify that the Power button is connected to the correct place.
-Verify the voltage selector on the Power supply is set to 115V (if that's what you have)
-Verify the Power supply's additional switch is set to on (if it has one on the back)
-Verify the CPU is seated correctly and securely.
-Verify there is no metal screws or anything like that sitting on the motherboard.
-Verify that the extra 4 Pin 12V connector is connected (if present on
this MB)
If none of this works, the motherboard might be dead.
Jan 10, 2010 | E-Machines Computers & Internet
My asus mother board not working
STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
2. or else...STEP: Check the Power Button LED on the Front of the Computer (on Blinking yellow)
Initial state of LED at power up.
Indicates system has power, but the POWER_GOOD signal is not yet active.
If the hard drive LED is off, it is probable that the power supply needs to be replaced.
If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed. Look at the diagnostic LEDs for further information. or lese..
3. STEP: Restart the Computer Using the Power Button.Press and hold the power button down until the computer powers off. This should not require more than 10 - 15 seconds.Press the power button to turn on the computer.
4. STEP: Verify the Power Supply Voltage Selector Is Correct for the Region. Verify the setting for the power supply:
*Unplug the power cable from the back of the system. *Press and hold the power button for at least 5 seconds to discharge remaining power.*Inspect the voltage selector setting on the back of the machine (Figure 1). Ensure that the voltage select is set in the correct position for the region the in which the system is operating: For Europe and Asia, the voltage setting should be 230V.In North America, Mexico, parts of Central and South America, and parts of the Caribbean, the voltage setting should be 115V.*Plug the power cord back into the back of the system.*Turn on the power.
STEP: Try a Different Known-Good Wall Outlet.
STEP: Remove All External Devices. Turn the system off.
Unplug everything from the front and back of the system except for the power cord or AC adapter, including: keyboard mouse monitor speakers printers scanners USB devices handheld PDAs external Zip or CD-R drives joysticks/game pads, etc
Attempt to turn the system on.
Blinking Amber/yellow: Initial state of LED at power up.
If all the lead is off, then have the mother board replaced
May 06, 2009 | Dell Dimension 2400 PC Desktop
I replaced the video card and it still will not boot up.
IF A&B are yellow and C&D are green it indicates a memory error.
If A&B are yellow and C&D are off then it indicates that the computer is in sleep or reduced power mode.
What was your symptoms before you replaced the video card? Sometimes if the power supply is weak or bad or you have a bad motherboard then you get no video output. Check your cpacitors on your mobo for leaking or swelling. Let us know what you find out.
Apr 30, 2009 | Computers & Internet
My computer does not switched on. Power supply is ok but not functioned by motherboard(Biostar). I am expecting your suggestions.
No Power, No POST, No Video
1. STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
Apr 29, 2009 | Computers & Internet
Won't boot
Apr 26, 2009 | Computers & Internet
Dell Power Up Problem
Apr 25, 2009 | Dell Inspiron 530 Desktop Computer
Power up
pull everthing off board but power supply ram cpu and heatsink. then try to power unit.
May 08, 2008 | E-Machines eMachines Desktop PC
Intel (5184-0062) Processor Board Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
