Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Cursor problem Hi, I have had my laptop for a couple of years now and from day one the cursor just seems to jump whenever the mood takes it. Not sure why or how it does this...it just does...usually mid-sentence or even mid-word. In fact whilst typing this message the cursor has jumped elsewhere in the message a number of times causing me to type absolute rubbish. It does this not only in emails but also in Word and any typing generally. Can anyone help? Please? Thanks Ash
    President:
  • 2,961 Answers
This is a common keyboard driver problem, go to my computer,right click>properties>hardware tab>device manager> and look down the list for keyboard, click the'+' sign, right click on the keyboard type line and select uninstall. Restart the notebook and it will automatically reinstall itself and the driver. If you still have the same problem, you will need to go to the manufacturer web site and download the latest keyboard driver if any, install it and repeat the above.
Posted on May 30, 2007
Jumping Cursor
hello dear ...Pleas turn off the touch pad (mouse)or take car about touch pad when you typinggood luck
Nov 23, 2011 | Dell Inspiron 1501 Laptop
Cursor jumps all over the place! Cursor "arrow" shifts to cursor "four-arrrow" then decides to change zoom level all on its own. Cursor disappears, is nowhere on the screen then...
The Touchpad is the cause. Although some work fine for years others jump the the pointer every time you type (or sneeze). You can turn the touchpad off if you have a mouse for the laptop. Otherwise, you might need to exchange/purchase another model laptop.
Oct 15, 2017 | Toshiba Satellite A355-S6930 16.0-Inch...
Hi, i have an Asus K52J model, i purchased it in the end of August so its only a few months old. I am studying abroad in Italy for the semester and am starting to run into some problems. It started out...
In my case, the cursor jumps around when I'm typing. It could jump one line up or back to the start of the line.
Anybody with an Asus K52J ever encountered this problem?
Nov 13, 2010 | ASUS Eee 4G Notebook
Jumping cursor of a
Hi! I think youre probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. You may got to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem. Thanks for visiting FixYa.com!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
My girlfriend's hp is jacked up. whenever she
Hi, the problem is coming from the keyboard. you can test by plugging an external keyboard and try typing on the external. you can replace the laptop keyboard if necessary.
Jan 26, 2010 | HP Pavilion dv5tse Notebook
I have an Acer laptop. While typing the cursor suddenly jumps up a couple of lines, or suddenly may highlight a phrase, causing instant erasure of the previously typed material. Why does cursor continually...
your palm might be hitting the touchpad causing your mouse cursor to move and jump around... try to type with only your fingers hitting the keys and the back of your hand raised and not hitting any part of your laptop... hope this helps....
Nov 10, 2009 | Acer Aspire 5315 Notebook
When I am typing he cursor jumps around
It is a fault with Lenovo laptops. My cursor jumps all the time, no matter what software I am using. It is NOT the 'sensitivity' of the touchpad, for my cursor jumps even when I am not typing, even if I don't touch the laptop! I can set the cursor to a certain point on a document and then, after about 30 seconds, it will just jump to another point, even if I am in another room.
Sep 24, 2009 | Lenovo 3000 Y410 Laptop
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
VAIO laptop cursor moves by itself
Sometimes the surface the mouse is on can make the curs or seem to have mind of its own. Does it behave this way all the time or just here and there.?
Mar 20, 2009 | Sony VAIO VGN-C140G/B Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
394 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
