Question about Uniden BC248CLT Base Scanner
Antenna connection
Antenna will not stay in my uniden BC248CLT scanner.
keeps falling over. it not making no connection.cannot pick up any
thing.i think connection is broke on the inside.i am a woman and
do not know alot.any thing cheap that can fix it.or would it be worth
  • 211 Answers
It sounds like you are right. While you may not be mechanically inclined, you can easily open the scanner to see what is wrong. Unplug it from the wall and turn it over, so that the bottom is facing up. Remove all of the screws you can see. A regular sized phillips screwdriver should do fine for this. If you have removed all the screws you can see, there may be some below the rubber feet on the bottom of the scanner. You can peel these off with a flat screwdriver. Once you have the screws out, gently remove the bottom panel. From here you likely will be able to see the antenna connector. Is the connector just separated from the board, or is the board cracked? If it is just separated, it can probably be soldered back into place. If the board is cracked, it may not be worth repairing.
Now for the fun part...if it looks like the connector just separated from the board, it needs to be soldered back onto the board. If you feel like you want to do it yourself, there are a ton of tutorials and videos on the internet on how to solder electronics. The iron you need will be in the 25 watt range, and can be found at Radio Shack, Fry's Electronics, or probably even a hardware store.
If you're not feeling super adventurous, there are probably many resources that can help you with this. Any TV or radio repair shop (the old style Mom and Pop ones--not Best Buy or the major chains) should be able to do it. If you cannot find one in your area, you may be able to find an amateur radio group in your area who may be able to point you in the right direction. Heck, they may even be able to fix it for you.
Good luck, and I hope this information helps get your scanner up and running in no time!
Posted on Feb 25, 2010
In moving we lost our antenna.. we can pick up the weather chammel with out a antenna, but that is all.. what kind of antenna do we need?? Radio Shack does not have anything they said would work.can you...
You need an antenna with a Motorola plug, also known as an automotive plug, and a 90 degree angle - or a swivel. You can pick one up on any of the scanner web stores (Scanner World, Scanner Master, Grove Enterprises, etc.) or on eBay. Here's a link to a current eBay listing:
Bill B.
Listening in since the 60's
Jan 04, 2011 | Uniden BC248CLT Base Scanner
Will the BC248clt receive aviation transmitions VHF and UHF?
Sorry, but the 248 does not cover either aircraft band. To pick up these bands (108-137MHz civil and 225-380MHz military) you'll need to move up to a scanner that provides coverage of these frequencies. For reasonable cost and ease of operation I recommend the BC370CRS.
Bill B
Jul 12, 2010 | Uniden BC248CLT Base Scanner
Ive got a Uniden BC248 CLT Base Scanner. In the back of it, there are two holes for input/output of some sort, What is the diference in the am radio antenna vs. the antenna ?
Your scanner has four connections on the back. Looking at the rear, from left to right, are the power jack (10 volts AC, you need an adapter for this), an external speaker jack, the AM antenna connection, and the scanner antenna jack.
The AM antenna jack is for the reception of AM radio station signals. The scanner antenna jack is for police/fire etc, as well as FM signals.
In case you don't have a manual for your radio, it is available for free here:
May 09, 2010 | Uniden BC248CLT Base Scanner
My mom's bc248clt stopped working. adjusted squelch but won't pick up signals. had it to a guy who repaired it in the past but he can't figure it out. Perhaps a programming problem? How can I reprogram?
Press manual,enter the channel number,press manual,enter the frequency you want,press E,if you make a mistake,press CLR twice to erase. ..hope this helps..
Mar 03, 2010 | Uniden BC248CLT Base Scanner
My bearcat scanner BC147xlt will not pick up codes in my area
Press the WEATHER button. If the scanner picks up a weather broadcast then you either have the wrong frequencies programmed in for your area, or it's possible that you're in a "dead" zone where you just won't receive much without an outdoor antenna. If no weather broadcast is received, chances are that the scanner's processor is "fried." Yours is an old scanner, and they do wear out.
For local frequencies, try or Both have excellent databases.
Aug 16, 2009 | Uniden BC248CLT Base Scanner
Will a close hanger work as an antenna on my uniden bc144xl scanner?
nope! buy a good anntenna that'll hook to the shouldn't need a big rooftop unit.. a simple antenna like on a portable should work fine.
Jul 04, 2009 | Uniden BC248CLT Base Scanner
Acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
Bearcat scanner bc248clt
I Need to no how to prograamed channel and scan
Sep 18, 2008 | Uniden BC248CLT Base Scanner
Uniden BC248CLT Base Scanner Logo
78 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
