Question about Brother MFC-7440N Laser Printer
TRYING TO PRINT ON LABELS AND IT DOESNT PRINT STRAIGHT
I'M TRYING TO PRINT ON LABELS AND IT DOESNT PRINT STRAIGHT WHATS THE PROBLEM
  • 3 Answers
Use the regular paper tray, not the manual tray.
Posted on Feb 12, 2009
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Print labels
Use MS Access to make labels wich have template for that.
Dec 30, 2013 | HP Photosmart C5280 Printer
I have a brand new zebra tlp2844 I have set it up with a resin ribbon, the print quality is very poor and patchy why is this ?
There are a couple of possible solutions.
1/ Resin ribbons are meant to be used on synthetic labels onle ie vinyl or polyester. If you are trying to print on paper labels then you will get a rubbish print. you need to use either a wax ribbon or a wax resin ribbon.
2/ If you are printing onto a synthetic labels and the print is light, try increasing the "print darkness" some times called contrast or heat or printhead setting.. This can be fount in the printer set up in the labels software you are using or in the print drive under "Print Preference"
Dec 16, 2012 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105sl can't connect to new windows 7 pc
What motherboard is in the computer? USB to serial drivers can be chipset specific.
Apr 01, 2017 | Office Equipment & Supplies
I am trying to make labels for cd's but they are not printing correctly. The sheets show the cd to the side of the page but it's only printing straight down the middle so it's not letting me print...
I had the same problem. The solution I came up with was to use Microsoft Publisher to print the labels. First I drew a circle about the size of the cd and another inside it for the centre. I printed it out on a plain sheet of A4 paper and measured held it over the label to see how they matched up. I dragged the circles in publisher using trial and error until the circles came out in the same place as the circles of the labels. Then I designed the label inside the circle using publisher and when I printed it on the label it came out in the circle.
If you don't have publisher just check the paper shown in your print dialog and make sure you have changed it to the label type you're using rather than A4 Plain which is the standard.
Jul 27, 2010 | Avery DesignPro Deluxe CD-ROM...
Printing labels
you may have to set the lables up on the bypass or manual feed input as the machine has to compensate for the thickness of the labels and slows the print process down. check the display on the copier it may be asking to load labels in the bypass
Nov 17, 2009 | Office Equipment & Supplies
HP Deskjet 6980 will not print Labels using Microsoft Word
You could be printing a font the printer does not know. Make sure it is capable of printing the version you are trying to use.
Jul 11, 2017 | HP Deskjet 6980 InkJet Photo Printer
Printing Labels
Sorry loose plug. All fixed!
Jan 06, 2009 | HP LaserJet 1020 Printer
Roxio Label Creator won't print labels (blank with scissors)
Go to the label creator in your Roxio 6, Click on EDIT, then click on PREFERENCES, go to the DISC tab and unclick the "Print Disc cut Lines" and the "Print Disc outline" boxes. This should fix your problem.
Sep 13, 2008 | Roxio Easy CD & DVD Creator 6...
Brother MFC-7440N Laser Printer Logo
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
