Question about Bunn VPR Coffee Maker
Coffee pot i just purchased a Bunn VRP Model no 1660 commercial 2 warmer coffee machine. The warmer units work fine, the main heating element for the water heats up too, all the lights work, but when I put in the water, nothing comes out. I have taken the pot apart to make certain all the connections are good and everything looks OK. There is what appears to be a switch or solonoid on top of the main heating unit. I an not sure how the water is expelled from the pot. Is there a pump or does it siphon itself out? I also checked for blockages and did not find any evidence of lime build up in the main tubes. Any ideas on why it is not sending water through?
  • Anonymous Sep 21, 2008
    water i holdin tank boils over
I am having the identical probem, I plug it in, it starts to heat, but no brewing. I have removed the lid and the water pan underneath, and looked into the opening. When heating, the voltage on the main heater is 110 volts. It stars to steam, then the unit switches off.I think that for some reason,it's not allowing the temp. to rise to the boiling point. Anybody have any ideas? I'll check on that one way valve in the meantime.
Posted on Jun 07, 2007
  • James Renner Jun 07, 2007
    Just took off the line that runs from the heating tank to the filler nozzle. There is no pickup tube, as I suspected. These "pour-through" type coffe makers use steam to brew the coffee. Look at bunns' website for a schematic. www.bunnomatic.com
    It must be either the thermosat or the limit thermostat.I'll post the prices of these when I contact Bunn.
    I have a solution. If you didn't fill up the machine with water, then it will never brew. I realized that what this is is basically a tank water heater that keeps water hot ALL the time. I didn't get a owner's manual with this ( yard sale) so I didn't realize what was wrong. Fiil up the resivior with water until it comes out the brewing side. Then turn it on. Wait a few minutes, then pour whatever amout of cold water into it. This cold water will displace very hot water through the small brewing tube, and that will brew your coffee!
  • 883 Answers
Many coffee machines use a check valve to direct the water in one direction. I suspect this check valve's ball is not moving (which is required)... look for a strange-looking (wider than other tubes) device in the water path...maybe part of a tube.
Posted on May 30, 2007
Our Bunn VRP SERIES MAKES NOISE WHEN WATER IN THE TANK SITS AWILE
There are two heaters in a VRP unit (Pour over style) The brewer has a tank that your last office person poured in a full pot of water. The main heater senses the colder water and begins to reheat the water to near boiling. The new water pushes out the same amount of water into the brewing basket (funnel with coffee). Once the new water has come up to temperature then the main heater turns off. There is a warming blanket around the inside tank. This keeps the water hot and ready to brew. It uses less power than the main heater. If this blanket fails then the water will cool down to a point where the main heater heats everything back up. You may not notice this as the only indication is luke warm coffee on a freshly made pot or a 'boiling' noise every 15 - 25 mins. This VRP probably needs servicing (check Thermal blanket and Thermal fuse)
Sep 17, 2017 | Bunn Coffee Makers & Espresso Machines
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
Mar 19, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Leak
your tank is leaking
Please Follow LINK for parts etc
Jun 12, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
208 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
