Question about Nikon LS 2000 Film Scanner
Nikon LS-2000 scanner gives error 0x04620000
When I turned on the scanner it functioned fine, but then it failed.  The above error was given that there was a hardware error.
  • SHERLOCK85 Feb 02, 2009
    I HAVE THE SAME TROUBLE. HELP SOMEBODY!!!
  • scricio Feb 08, 2009
    same
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Posted on Apr 12, 2009
The Nikon LS 2000 Film Scanner says the stage locking screw is still in place but it was removed 10 years ago when I bought it. I tried to put the negative film adapter in, it didn't work. Then I put the...
The lubricant has become sticky and is acting more like adhesive than lubricant. This is the most common cause of malfunction in the LS-2000 and LS-30 scanners. It's a quite curable condition.
Nikon LS-2000 and LS-30 film scanner service and repair is available. Check seller pjferrante2 on eBay. Scanner performance backed for 12 months. Very reasonable price.
Dec 19, 2010 | Nikon LS 2000 Film Scanner
My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
http://www.pcreview.co.uk/forums/thread-1936922.php
Dec 03, 2009 | Nikon LS 2000 Film Scanner
Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
Oct 29, 2009 | Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software (www.hamrick.com). This works perfectly on LS2000 - Macbook Pro combo.
Jun 02, 2008 | Nikon LS 2000 Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Install Nikon Scanner LS 2000 on Windows XP Professional
Scanners made for DOS based systems seldom work with HTFS systems.
There were some fixes attempted but generally a no go situations.
You could try the following
Start/Programs/.Accessories/ programs
Compatibility Wizard and set the computer to run as Win 98 with this particular software.
Dec 30, 2007 | Nikon LS 2000 Film Scanner
Nikon LS 2000 hardware problem
Here's what you need to do (carefully!!):
www.vad1.com/photo/dirty-scanner/ls2000-cleaning/
Dec 08, 2007 | Nikon LS 2000 Film Scanner
Hardware error
the problem is that the scan sledge gets stuck if arriving at end of screw. To fix:
Open scanner by unscrewing the four screws in the back - this will allow ypu to slide the sides slighly backwards and then remove. Then take the plastic front of (press the plastic tap on top with screwdriver). You will the see a small brass screw center bottom at the front. Loosen this a few turn and try again (you may have to try a few times)...
Good luck
Nov 20, 2007 | Nikon LS 2000 Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Nikon LS 2000 Film Scanner Logo
969 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
