Question about Canon EOS-10D Digital Camera
10D Canon SLR can't start up
Not sure what is happening but my 10D went dead. I recharged the battery and made sure it is fully charge (i am quite sure there is nothing wrong with my battery) but my 10D still wouldn't start up. I am wondering if this has got anything to do with the coin-sized battery that is at the bottom of the camera and i am thinking of replacing it. Would that help? Please can anyone help
If you have a dead storage card, that will do it too.
I had a Lexar card go bad and with it in the camera, it was totally non functional. I inserted another card and all was well!
Posted on Nov 29, 2007
    Genius:
  • 2,985 Answers
Well replace it by all means - what does the Manual have to say about this particular battery It is usual for a full manual to be on a PDF file on the software disk - have you checked this out? If all else fails- Canon Technical Support is the next stop
Posted on Jul 22, 2007
How to replace clock battery in eos rebel ll
your "clock battery" is just a very little rechargeable battery, that will charge as soon as you put in a fully charged battery in your camera. You should wait for at last 12 hours, before you remove the battery. and the little battery can keep the clock running for several days.
Everything that is in the camera, only can be replaced by a skilled electronics engineer. The best thing you can do is contact a certified Canon repair centre and ask what it will cost to build in a new clock battery. But before you think it is a clock battery, make sure your battery is still in working order. Ask around if anyone you know has the same camera and borrow a charged battery for a few moments, to make sure it is not you camera battery.
Apr 19, 2014 | Canon EOS Rebel G 35mm SLR Camera
Battery door
To purchase a battery door for your D10, go to eBay and search for "10D battery door." You will see several for sale and they run around $7.00.
Hope that helps,
BAX
Jan 07, 2014 | Canon EOS 10D 35mm SLR Camera
Battery died, recharged it now it wont turn over
Your battery is toast. It may read 12.6volts but does not store the power it needs start the car. Get a new battery.
Dec 27, 2017 | 2008 Hyundai Santa Fe
.HAVEN'T USED 10D FOR A LONG LONG TIME AND
Here are a few things to try:
1. Remove the main battery and the small backup battery (CR2025) from the battery compartment. Charge your main battery and put both batteries back in once your main battery has been charged. Sitting without batteries will give the camera a chance to reset itself.
2. You may have a bad CF card. Try starting your camera without a CF card or use another.
3. Try reloading the firmware (camera's operating system) using this link Canon. http://web.canon.jp/imaging/EOS10D/10D_firmware-e.html
Be careful to follow instructions exactly as restarting the camera in the middle of a firmware update will brick it and you will need to send it back to Canon for repair.
Hope that helps,
Bax
Oct 11, 2011 | Canon EOS 10D 35mm SLR Camera
I have Cannon EOS Rebel xsi. The camera does not take picture when press the shutter in all modes. There is no error message. Have change the memory card, recharge the battery and none work.
Hello Sure !
The probleme :
The Shuteer Has A cable Connected to Recorder
Maybe The cable Has Cutted when you Shut ,or Maybe Cutted When You Charged The Battery cause When your put your camera on the charge , the cable goes be hot and it should be cutted .
Solving The Probleme :
1) I advise You To Change The Cable
2) Push The Reset Button
3) Charge It Again
It works 100%
Fix-shad0w
Aug 03, 2010 | Canon EOS 10D 35mm SLR Camera
I have a 10d digital camera. battery gos dead after shooting 15+
Try cleaning your battery terminals. You can use a little rubbing alcohol on a q-tip. If you are still having issues then you will need to get another battery as that battery is shot
May 27, 2010 | Canon EOS-10D Digital Camera
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
Need a canon 10 d manual
Manual for EOS 10D PLS RATE ME FIXYA FOR HELP
http://gdlp01.c-wss.com/gds/0900000229/EOS10DIM-EN.pdf
all downloads for EOS 10D
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=325&modelid=8772
Apr 03, 2009 | Canon EOS 10D 35mm SLR Camera
Canon 10d won't turn on
well got a little advice from a friend and here is what he suggested the lens might not be on all the way so try taking it off and putting it back on as stupid as this sounds it actually worked when i did it on mine also even though you've probably done it already clean the battery's contacts and the ones in the camera and hopefully that's all the bigger the problem is. good luck
Nov 23, 2007 | Canon EOS-10D Digital Camera
Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Canon EOS-10D Digital Camera Logo
195 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
