Question about Mitsubishi WS-55809 55" Rear Projection Television
Picture is curved whe you turn on the tv.
When you turn on the tv the picture curved distorting the picture in shape and focus. For now after a few minutes the picture corrects and is fine. The problem seems to be getting worse in how the the picture corrects itself.When first turned on , green and red colors do not line up,picture is curved and out of focus. After a few minutes the problem seems to correct itself
  • 15,935 Answers
If your good with a sodering gun and know how to work on printed circuit board, yes you can change the IC's your self for about 50 or so bucks, but if you have no solid state repair experience, I highly advise you to call a pro to assist you with this repair. You will need to get a service manual, the IC,s and then after that you would need to put the TV set into the service mode and make the necassary aligments to the set as well as the convergence circuit.
And I'm afraid that when the IC(s) blew out, it may have taken out a resistor or pico fuse out with it and you will now most likely need the service manual so you can check the voltages on the convergence IC's.
This is not a common DIY'ers fix. Please seek Professional help.
Posted on Jan 07, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jan 07, 2009
    All you need is a set of convergence amps, a temperature controlled soldering iron with a small pointy tip to get between the pins on the IC and some Chemwick Lite in the blue package and some 63/37 solder and some heat sink compound....
    Install them and VOILA....job done.
    You don't even NEED a set of schematics for that job.....
  • blueextc3221
    Go here, and enter your model #... you can see the user manual for the TV
    http://www.mitsubishi-tv.com/support.htm...
  • blueextc3221
    Click support documents, enter your model #, and on page 47 it goes into detail about setting the convergence.
    Novelist:
  • 123 Answers
The mechanism that lines up the 3 color lenses is not self-calibrating properly. Probably needs to be returned to a repair service.
    Novelist:
    Scholar:
  • 67 Answers
If a problem corrects itself after a few minutes, you probably have a bad capacitor in the convergence/pincushion circuit of the TV. It has probably drifter out of specification, and is near the end of it's life.
Any competent repair shop should be able to help you for around 100 dollars.
Hope this helps you...
  • waynejamescm
    waynejamescm Jan 07, 2009
    Oh, and Convergence IC's usually go out all together. If the problem corrects itself, I doubt very seriously that is a convergence IC issue.
    President:
  • 2,110 Answers
Convergence board
You problem is the convergence IC's. This is much less expensive to fix than a red crt. Sometimes it is bad connections. Can you tap on the side of the tvand make the red correct itself?. If not, have the convergence IC's replaced and the problem will be solved.
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture goes diagonal
U know how to solders?Ur convergence it dead,must replaced.Tries these websites for convergence kit.Tv repair World.com,Tv repair kits.
Nov 13, 2009 | Toshiba 50HM66 52" Television
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Oct 05, 2007 | Televison & Video
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
KP-57WS500
Sounds like a conergence circuit failure, probably a couple of AMPs and a few discreet components. Probably 250-300 repair
Apr 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
