Question about Microsoft Windows Vista Ultimate Edition
When i want to turn off the computer, the pc will not shut down u
The pc will not shut down unless i switch off the power supply.
    Problem Solver:
  • 12 Answers
Hey,
try to run CHKDSK:
1. Click Start, and then Run.
2. Type cmd, and then press ENTER.
3. At the command prompt, type:
chkdsk drive: /f /r
Posted on Jan 08, 2009
Computer has not power
If the power supply is bad replace it.
If the computer boots up for a second and then shuts down you can try the following method:
Remove the battery for a few minutes, put the battery back. Locate the connection to the power switch, turn computer on and then quickly disconnect the power switch
. If you have a battery with a power switch you can use that instead. Otherwise if this method solves your problem you will have to turn the computer on and off by plugging and unplugging it.
If you are going to get a new power supply, look for one that has a power switch on it.
Dec 14, 2010 | Acer Power FG (APFGUP5161) PC Desktop
I have a Dell Dimension 5100, after a power outage yestarday, the computer doesnt want to turn on. there is a green light in the motherboard that stays green for as long as i have power conected to the...
The greenlight is probably the UPS [Uninterruptible Power Source]. If the computer was shut down by a normal windows shutdown and the UPS remained plugged into the 120 Volt line and the computer's power supply plugged into the UPS and the UPS NOT turned off, there would still be 5 volt standby voltage applied to the computer's motherboard. ATX type computers never go completely off unless the power supply is turned off or unplugged.
That 5 volts would have to on steadily for the rest of the voltages from the supply to turn on.
If there is a reset button or on off switch at the back where your power cord plugs in toggle it back and forth. You can also try disconnecting the power supply and holding the power button in for about 15 seconds to discharge power.Leave it unplugged for a few minutes. Then try powering it back up again. If those don't work then you might have a bad power supply. They are not hard to replace.
Hope it helps
Nov 20, 2010 | Computers & Internet
My computer wil not shut down it re boots straight away
Hold the power switch down until the computer shuts down all the way. It should not reboot again unless you have a bad power switch.
Nov 01, 2010 | Evesham Computers & Internet
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
The computer suddenly shut off and will not turn back on. I assume the power supply is shot. The computer was kept on constantly, and was seldom shut down. I have opened up the case and it is extremely...
there are two posibilities...
1 ur power supply is out, to check if ur power supply is OK, check if fan on power supply is running when u switch on the PC, if it works then that's OK
2 - ur motherboard is out, if this is the case ur CPU fan will not work but ur power supply fan will work
to check both u may have to open the PC
Dec 14, 2009 | Sony VAIO PCV-RX470DS PC Desktop
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
My philips tv won't turn on.
Very unlikely to be the switch. With the power supply shutting down, the problem is probably in one of the circuits that is supplied by it. Unless you know what you are doing, leave it to a technican.
Dec 30, 2008 | Philips Televison & Video
My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Nov 18, 2008 | Computers & Internet
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
