Question about Nutrifaster Ruby 2000 Juicer
I have a Ruby 2000 juicer. It is tripping the breaker when I try to turn it on...any suggestions would be appreciated...thanks Cindy
    Problem Solver:
  • 14 Answers
Short in the wiring of the motor or defective switch or powercord
info@nutrifaster.com.au
Posted on Aug 01, 2013
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out info@nutrifaster.com.au
Jul 13, 2013 | Nutrifaster Ruby 2000 Juicer
What is the difference between the Ruby 2000 and Nutrifaster N350? Were they once produced by the same manufacturer?
If both juicers were purchased in Australia the same the brand name changed in 2001 from Nutrifaster the company to The Ruby Juicer
Feb 25, 2013 | Nutrifaster Ruby 2000 Juicer
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Have just bought a secondhand Ruby and replaced the blades and basket - still having problems with the basket collecting pulp (apples) and becoming noisy - unbalanced I assume. When I clean out the basket...
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
Feb 13, 2011 | Nutrifaster Ruby 2000 Juicer
I need a Ruby 2000 manual. How can I get it?
Go to the Nutrifaster Australia website and you will find it
Click on this link: http://nutrifaster.com.au/juicing-bar-equipment/multifruit-juice-extractors/4:1155/
Dec 28, 2010 | Nutrifaster Ruby 2000 Juicer
Broken side clip on cover of juicer
The main problem is that the CLIP needs to be adjusted in order to have the correct pressure adjustment the lever clip should be at a 45 degrees level once is clipped at the bottom anchorage it will be OK to much pressure will brake the securing pins of the unit info@nutrifaster.com.au
Oct 08, 2010 | Nutrifaster Ruby 2000 Juicer
Bearing noise
Why don't you contact Nutrifaster as see if they can assist?
Nov 01, 2009 | Nutrifaster Ruby 2000 Juicer
Nutrifaster N450 hex nut stuck
Your unit is a Nutrifaster not a Ruby juicer tray again their website of Nutrifaster in Seattle USA...good luck
Aug 30, 2008 | Nutrifaster Ruby 2000 Juicer
Nutrifaster Ruby 2000 Juicer Logo
135 people viewed this question
Top Nutrifaster Juicers Experts
eyecam
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
