Question about LG LMV1650ST Microwave Oven
Lg model 1650st does not heat makes a buzzing sound
  • William Miller
    William Miller May 11, 2010
    Sorry, I meant to ask if it's MV-1650ST?
  • William Miller
    Is your model number actually MV-150ST?
    I'd suspect the magnetron or high voltage diode, but please reply back with
    your brand and full model number from the tag so we can help you
    properly.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Kenmore Over the Range Microwave making buzzing sound and not heating
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
Jul 18, 2012 | Microwave Ovens
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | GE Profile Over-the-Range Microwave
My GE Space Saver Microwave that comes on but makes a buzz sound in operation and does not heat.
If it buzzes before you hit "Start", you may have a control circuit board problem or a door switch problem.
If it buzzes after you hit "Start", you would probably have a bad magnetron and/or high voltage rectifier diode.
We would need more details no the failure and of course the full model number to help you further.
Jun 20, 2011 | GE Microwave Ovens
My microwave no longer heats anything and also makes a really loud buzzing sound when i attempt to use it.
The problem is most likely caused by a defective magnetron that "heats the food" is loading down the high voltage transformer causing it to make a loud buzzing sound. The cost to repair (depending on make and model) will probably approach the cost of a new microwave oven when you factor parts and labor.
Jan 23, 2011 | Microwave Ovens
Everything works but "heating". Makes grinding
The loud buzzing sound with no heating, is symptom that the magnetron has failed in your oven. Magnetron replacement cost are almost as much as new oven, so it does not make financial sense to repair. Sorry.
Jan 21, 2011 | Panasonic Microwave Ovens
Works but no heat or cooking
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | LG LMV1630ST Microwave Oven
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
GE Microwave does not heat and makes loud buzzing noise.
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
Dec 10, 2008 | Whirlpool GH8155XM Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
LG LMV1650ST Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
