Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Samsung HLN4365W picture not centered
I've tested all the inputs and the screen is shifted horizontally left about 1 to 1.5 inches, the vertical position is fine. I checked all the settings and have found no picture adjustment. I have had the set apart to replace the lamp and colorwheel over a year ago. Not sure when the issue started but just noticed it recently.
  • Daniel Baker
    Daniel Baker Jan 13, 2009
    I found the menu and the following options are available;
    1. DDP1010 (ALL)
    2. DNIe (ALL)
    3. AD9883 (Component/480P)
    4. 3D_COMB (ALL)
    5. OPTION
    Three options are grayed out and I have looked under all the menu's and haven't seen something that resembles vertical or horizontal adjustment. Plus with the screen being black how can I see if the adjustment I make is correct?
  • Daniel Baker
    I found the horizontal adjustment under the DDP1010 menu, it was listed as Pos-X.
    i also turned on the DVD player then did the mute 1 8 2 power and the menu came up with the DVD in the background. so I was able to see the picture move. not to mention I had it set on wide instead of normal. once in normal I adjusted the screen from 152 down to 103. I checked with a tape measure and got the screen pretty much centered.
  • 133 Answers
Turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Posted on Jan 09, 2009
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Aug 22, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Picture is off center. Bottom edge is about
sounds like VERTICLE problems...check verticle circuit for bad Capacitor...bad cap might be visible...you must locate verticle ckt inside of TV and change BAD cap!!!
May 19, 2010 | Samsung HLN4365W 43" Rear Projection...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
MY TV SONY KV27FS12 PICTURE PROBLEME
Hey Rolly no problem man as if we can help ya your not taking up our time as we answer when we can. Ok theres is still a small cap somewhere by the drive ic or they call it the jungle ic. If you have a schematic scan the vert part and I will assist you the best i know how.
Apr 14, 2006 | Sony KV-27FS12 27" TV
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
302 people viewed this question
Henry  Thomas
Henry Thomas
